Problem building master
Isaac Gutekunst isaac.gutekunst at vecna.com
Mon Mar 7 17:57:18 UTC 2016
Okay, main problem was combination in a bad rebase, followed by a lack
of bootrap -p.
I have a new problem, but for organization I'll start a new thread.
On 03/07/2016 12:35 PM, Joel Sherrill wrote:
> On Mon, Mar 7, 2016 at 11:15 AM, Isaac Gutekunst
> <isaac.gutekunst at vecna.com <mailto:isaac.gutekunst at vecna.com>> wrote:
>     I think I've found some git trouble going on, so I'll give that a
>     shot. I think I might have a strange hybrid of the 4.11 and 4.12
>     branch due to a nasty rebase.
> Sometimes I ended up in strange situations with git also. 99% of the
> time all is well
> but I still screw things up occasionally.
> I hope it helps.
> --joel
>     Isaac
>     On 03/07/2016 11:54 AM, Isaac Gutekunst wrote:
>         ../rtems/configure --enable-rtemsbsp="stm32f7x"
>         --enable-maintainer-mode
>         --disable-tests  --enable-cxx  --target=arm-rtems4.12
>         --prefix=$RTEMS/lib-rtems --disable-networking
>         Since this is still our unreleased BSP, there could be some issues
>         related to it. I'm just not sure what to look for.
>         I built GCC last week I believe.
>         Here is the --version output:
>         arm-rtems4.12-gcc (GCC) 6.0.0 20160228 (RTEMS 4.12, RSB
>         b537e5536459e207fc8e56a1df3774c1700606d5, Newlib 2.3.0.20160226)
>         Isaac
>         On 03/07/2016 11:32 AM, Joel Sherrill wrote:
>             This is odd. I just did a fresh update and rebuilt sparc/sis
>             with POSIX
>             enabled.
>             I didn't have trouble.
>             The gcc+newlib version bumped last week but that shouldn't
>             have had an
>             impact
>             yet and wouldn't have broken this. It added prototypes for a
>             few pthread
>             routines
>             I am adding.
>             How did you configure exactly?
>             --joel
>             On Mon, Mar 7, 2016 at 9:24 AM, Isaac Gutekunst
>             <mailto:isaac.gutekunst at vecna.com>>> wrote:
>                  Correcting my subject typo.
>                  On 03/07/2016 10:23 AM, Isaac Gutekunst wrote:
>                      Hi,
>                      I'm trying to build RTEMS master for ARM, and am
>             getting the
>                      following
>                      compile error:
>             ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:
>             In
>                      function 'pipe_interruptible':
>             ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:76:34:
>                      error: 'Thread_queue_Control {aka struct
>             <anonymous>}' has no
>             member
>                      named 'state'
>                           the_barrier->Barrier.Wait_queue.state |=
>                      STATES_INTERRUPTIBLE_BY_SIGNAL;
>             ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:80:34:
>             member
>                      named 'state'
>                      I can't seem to find a definition for the
>             Barrier_Control struct,
>                      andhaven't been able to find a root cause.
>                      It could as always be a bootstrapping/cleaning
>             problem where the
>                      wrong
>                      file is being built, but I don't think so.
>                      Anyone know what's going on?
>                      Thanks,
>                      Isaac
>                      _______________________________________________
>                      users mailing list
>             users at rtems.org <mailto:users at rtems.org>
>             <mailto:users at rtems.org <mailto:users at rtems.org>>
>             http://lists.rtems.org/mailman/listinfo/users
>                  users mailing list
>         users mailing list
>     users mailing list
