users Digest, Vol 113, Issue 42
Matthew Clark
linux.matthew at gmail.com
Thu Mar 10 14:51:18 UTC 2016
On Fri, Feb 26, 2016 at 5:24 PM, <users-request at rtems.org> wrote:
> Message: 4
> Date: Fri, 26 Feb 2016 16:24:18 -0600
> From: Joel Sherrill <joel at rtems.org>
> To: Matthew Clark <linux.matthew at gmail.com>
> Cc: "rtems-users at rtems.org" <users at rtems.org>
> Subject: Re: Running ARM or PPC RTEMS simulations on x64 hardware
> qemuppc is a PowerPC BSP that runs on the qemu simulator.
> The ARM simulator in gdb does not know how to run this. Qemu is the
> simulator for the xilinx_zynq_a9_qemu BSP.
> You will need to build qemu with the RSB and install it.
> Then there are some easy to use helper scripts in the rtems-testing/sim-scripts
> directory named after the BSP they are invoking a simulator to simulate. So
> you would invoke it as:
Joel,
Is there a guide for building these simulator for other platforms? I
want to do the
same for my Raspberry Pi2 and a PPC QorIQ board, but from what you're
describing,
I need to build one against the RSB and don't know exactly how.
Thanks,
Matt
