4.12 on MVME6100 (beatnik)
Heinz Junkes
junkes at fhi-berlin.mpg.de
Tue Mar 15 12:12:51 UTC 2016
It works with 4.11 branch.
Will check differences to 4.12
Heinz
> On 14 Mar 2016, at 14:02, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 11, 2016 at 5:21 AM, Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hi,
> does anyone got the RTEMS 4.12 running on the beatnik (MVME6100)?
> This is unfortunately an example where we rely on the community to periodically
> test. If no one checks in a while, ... :(
> We can’t get one of the examples booting on that target. It stucks in the startup routine.
> It does not reach the bsp_start routine.
> Is the executable even well-formed? Does the format and address map look correct per
> the one that works? Entry point the same, etc.
> Examples are running with 4.12 on an older VMEbus-Board (MVME2100) with just some litte issues.
> With this version:
> commit 9827d51e7405aad26d3eda2d3fb82504b7fa68c3
> Author: Joel Sherrill <joel.sherrill at oarcorp.com>
> Date: Wed Oct 8 09:24:02 2014 -0500
> gen5200/startup/cpuinit.c: Warning for function which should have been void
> On the MVME6100
> ticker.ralf works with RTEMS 4.10 compiler
> ticker.ralf fails with RTEMS 4.12 compiler
> any ideas?
> Does it work on the 4.11 branch?
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160315/446fe93a/attachment.bin>
