conflicting types when building rtems-libbsd
Tue Mar 15 20:39:14 UTC 2016
Yeah, change this pci_ stuff in bsp to use an rtems safe namespace...
On Tue, Mar 15, 2016 at 3:41 PM, Josh O'Guin <Josh.OGuin at oarcorp.com> wrote:
> From my understanding, Joel recently added pci_find_device to the RTEMS
> code.  It is now conflicting with the pci_find_device in libbsd when I try
> to build.  Does anyone have any suggestions on resolving this problem?  Here
> is my output for details.  Thanks.
> [433/845] Compiling freebsd/sys/dev/sdhci/sdhci.c
> In file included from
> /home/josh/development/rtems/bsps/4.12/i386-rtems4.12/pc386/lib/include/bsp.h:62:0,
>                  from ../../freebsd/sys/dev/sdhci/sdhci.c:62:
> /home/josh/development/rtems/bsps/4.12/i386-rtems4.12/pc386/lib/include/rtems/pci.h:1234:1:
> error: conflicting types for 'pci_find_device'
> pci_find_device(
> In file included from ../../freebsd/sys/dev/sdhci/sdhci.c:45:0:
> /home/josh/development/rtems/rtems-libbsd/freebsd/sys/dev/pci/pcivar.h:460:10:
> note: previous declaration of 'pci_find_device' was here
> device_t pci_find_device(uint16_t, uint16_t);
> Waf: Leaving directory
> `/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386'
> Build failed
> -> task in 'bsd' failed (exit status 1):
>         {task 3070316204L: c sdhci.c -> sdhci.c.16.o}
> ['/home/josh/development/rtems/4.12/bin/i386-rtems4.12-gcc', '-qrtems',
> '-B/home/josh/development/rtems/bsps/4.12//i386-rtems4.12/lib/',
> '-B/home/josh/development/rtems/bsps/4.12//i386-rtems4.12/pc386/lib/',
> '--specs', 'bsp_specs', '-mtune=i386', '-mtune=i386', '-ffunction-sections',
> '-ffunction-sections', '-fdata-sections', '-fdata-sections', '-std=gnu11',
> '-O2', '-g', '-fno-strict-aliasing', '-ffreestanding', '-fno-common', '-w',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/rtemsbsd/i386/include',
> '-I/home/josh/development/rtems/rtems-libbsd/rtemsbsd/i386/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/sys/i386/include',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/sys/i386/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/rtemsbsd/x86/include',
> '-I/home/josh/development/rtems/rtems-libbsd/rtemsbsd/x86/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/sys/x86/include',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/sys/x86/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/rtemsbsd/include',
> '-I/home/josh/development/rtems/rtems-libbsd/rtemsbsd/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/sys',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/sys',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/sys/contrib/altq',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/sys/contrib/altq',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/sys/contrib/pf',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/sys/contrib/pf',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/include',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libc/include',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libc/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libc/isc/include',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libc/isc/include',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libc/resolv',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libc/resolv',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libutil',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libutil',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libkvm',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libkvm',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libmemstat',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libmemstat',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/lib/libipsec',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/lib/libipsec',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/contrib/libpcap',
> '-I/home/josh/development/rtems/rtems-libbsd/freebsd/contrib/libpcap',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/rtemsbsd/sys',
> '-I/home/josh/development/rtems/rtems-libbsd/rtemsbsd/sys',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/mDNSResponder/mDNSCore',
> '-I/home/josh/development/rtems/rtems-libbsd/mDNSResponder/mDNSCore',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/mDNSResponder/mDNSShared',
> '-I/home/josh/development/rtems/rtems-libbsd/mDNSResponder/mDNSShared',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/mDNSResponder/mDNSPosix',
> '-I/home/josh/development/rtems/rtems-libbsd/mDNSResponder/mDNSPosix',
> '-I/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/testsuite/include',
> '-I/home/josh/development/rtems/rtems-libbsd/testsuite/include',
> '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1', '-DHAVE_DLFCN_H=1',
> '-DHAVE_RTEMS_PCI_H=1', '../../freebsd/sys/dev/sdhci/sdhci.c', '-c', '-o',
> '/home/josh/development/rtems/rtems-libbsd/build/i386-rtems4.12-pc386/freebsd/sys/dev/sdhci/sdhci.c.16.o']
> users mailing list
> users at rtems.org
