RTEMS ARMv8 Port
Raghav Nayak
raghav.nayak at nxp.com
Wed Mar 16 09:32:59 UTC 2016
Hi,
I am trying to configure RTEMS for ARMv8 target. Tried running the following command:
../configure --target=aarch64-rtems4.12 --enable-rtemsbsp=raspberrypi --enable-tests=samples --enable-networking --enable-posix --prefix=/mnt/FSL/pandora/rtems/rtems-armv8-bsp/4.12
But not able to get the output something like this:
target architecture: aarch64.
available BSPs: raspberrypi.
'make all' will build the following BSPs: raspberrypi.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
config.status: creating Makefile
Do you have any clues?
With Regards
Raghav
URL: <http://lists.rtems.org/pipermail/users/attachments/20160316/6782f108/attachment.html>
