RTEMS ARMv8 Port
Raghav Nayak raghav.nayak at nxp.com
Thu Mar 17 07:34:25 UTC 2016
Gedare,
It would be great if you could tell where exactly you do "Init" (HelloWorld entrypoint) context store so that  "_CPU_Context_restore" can get proper context of the thread before launching
Thanks
With Regards
  Raghav
-----Original Message-----
Sent: Thursday, March 17, 2016 12:39 PM
To: 'Gedare Bloom'
Cc: 'joel at rtems.org'; 'Jan Sommer'; 'rtems-users at rtems.org'
Subject: RE: RTEMS ARMv8 Port
Gedare,
I am trying to run RTEMS ARMv8 Port on GEM5 Model. I am hitting some issues on "_CPU_Context_restore" part. After digging through the flow there is "_Per_CPU_Information" from where whole thread context is to be loaded back to register in context restore code. Could you please help me understand this section
Thanks
With Regards
  Raghav
Sent: Wednesday, March 16, 2016 8:09 PM
To: 'Gedare Bloom'
Cc: joel at rtems.org; Jan Sommer; rtems-users at rtems.org
Gedare,
Changing link format I could build properly. Thanks
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
Sent: Wednesday, March 16, 2016 7:30 PM
To: Raghav Nayak
Subject: Re: RTEMS ARMv8 Port
Check where the link fails. Maybe the target binary output format is not supported by the linker for some reason.
On Wed, Mar 16, 2016 at 9:54 AM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
> Gedare,
> Currently I have put necessary port for ARMv8 to run "HelloWorld" App.
> But hitting some issue while linking final hello app
> With Regards
>   Raghav
> Of Gedare Bloom
> Sent: Wednesday, March 16, 2016 7:22 PM
> To: Raghav Nayak
> Raghav,
> In addition to the RTEMS toolchain, you must have a port of RTEMS itself to the target architecture. This involves probably a week or two of engineering effort.
> On Wed, Mar 16, 2016 at 9:48 AM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
>> Hi Joel,
>> Currently I am using the RTEMS toolchain for ARMv8 through Source
>> Builder
>> With Regards
>> Raghav
>> From: users [mailto:users-bounces at rtems.org] On Behalf Of Raghav
>> Nayak
>> Sent: Wednesday, March 16, 2016 6:51 PM
>> To: joel at rtems.org; Jan Sommer
>> Cc: rtems-users at rtems.org
>> Hi Joel,
>> I could build to some extent and when it comes to application it says
>> “error: Cannot change output format whilst linking AArch64 binaries”.
>> Any hints to resolve this problem ? Thanks
>> With Regards
>>   Raghav
>> From: Joel Sherrill [mailto:joel at rtems.org]
>> Sent: Wednesday, March 16, 2016 6:05 PM
>> To: Jan Sommer
>> Cc: rtems-users at rtems.org; Raghav Nayak
>> On Mar 16, 2016 7:26 AM, <soja-lists at aries.uberspace.de> wrote:
>>> Am 2016-03-16 10:32, schrieb Raghav Nayak:
>>>> Hi,
>>>> I am trying to configure RTEMS for ARMv8 target. Tried running the
>>>> following command:
>>>> ../configure --target=aarch64-rtems4.12
>>>> --enable-rtemsbsp=raspberrypi --enable-tests=samples
>>>> --enable-networking --enable-posix
>>>> --prefix=/mnt/FSL/pandora/rtems/rtems-armv8-bsp/4.12
>>> I am no expert in this, but I highly doubt that this is supposed to work.
>>> So far you only have a cross-compiler for RTEMS for the aarch64 target.
>>> However, as ARMv8 is a new architecture for RTEMS I would expect
>>> that you need to first add support for this new architecture to the
>>> RTEMS-kernel and probably the configure scripts as well. I have
>>> never done this, so I can't help here. The RTEMS porting guide might
>>> be a first step in understanding what you have to do:
>>> https://docs.rtems.org/doc-current/share/rtems/pdf/porting.pdf
>>> Another thing is that you want to build the raspberrypi-bsp. I
>>> assume you want to build RTEMS for the raspberry pi 3. The new
>>> raspberry uses another cpu as the older versions and of a different
>>> target architecture. That means from the operating system's point of
>>> view it differs significantly from the older ones, thus you cannot
>>> expect that the bsp for the RPi 1 and RPi 2 will work for the RPi 3.
>>> No one has added support for the RPi 3 yet. It's very new on the
>>> market and RTEMS has currently no ARMv8 support.
>> That's the basics. A new architecture requires adding
>> score/cpu/aarch64 and a new BSP for that architecture
>> c/src/lib/libbsp/aarch64/NEWBSP. I added the GNU tools support.
>> I did notice that gdb has a simulator for aarch64 which means a BSP
>> for that is simple to construct. The gdb simulator is similar on all
>> architectures and we have BSPs for a variety to use as examples. This
>> would be enough to debug core functionality on the aarch64 and run
>> the tests without interrupt support.
>> Then you have to add interrupt support and move to real HW and add a
>> second BSP.
>>>> But not able to get the output something like this:
>>>> target architecture: aarch64.
>>>> available BSPs: raspberrypi.
>>>> 'make all' will build the following BSPs: raspberrypi.
>>>> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
>>>> config.status: creating Makefile
>>>> Do you have any clues?
>>>> With Regards
>>>>   Raghav
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
>> users mailing list
>> users at rtems.org
