Help regarding buildin SPARC tool set
soja-lists at aries.uberspace.de soja-lists at aries.uberspace.de
Thu Mar 17 10:03:03 UTC 2016
Am 2016-03-17 10:46, schrieb Parthiv Parikh:
> I was getting started with the hello world. I completed all the steps
> successfully but i seem to have stuck on building the SPARC tool set.
> I entered the following command "
> ../source-builder/sb-set-builder --log=l-sparc.txt \
> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
> the building went on for a few minutes then it seems to have stuck on
> "building:
> sparc-rtems4.12-gcc-6-20160228-newlib-2.3.0.20160226-x86_64-linux-gnu-1
> I aborted it after around 35 minutes.
How many cores do you have on your machine? Compiling gcc might take a
while (even more than an hour).
If something goes wrong the RSB will usually tell with a build-failed
message.
I couldn't see the log file. Maybe it was to large for my mail provider.
Best regards,
    Jan
> I have attached the log file. Kindly guide me on how I should proceed.
> Thanks.
> users mailing list
> users at rtems.org
