Help regarding buildin SPARC tool set
Parthiv Parikh
parthiv.parikh95 at gmail.com
Thu Mar 17 12:24:34 UTC 2016
I ran the command once again and this time i let it build. I got an error
message in the end after 40 minutes.
"error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
Build FAILED
See error report:
rsb-report-sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1.txt
Build Set: Time 0:41:59.278169
Build FAILED"
I checked the error report it says "python is missing or unusable". I
checked through terminal and found that python 2.7 is installed and running.
I am attaching the error report.
On Thu, Mar 17, 2016 at 3:33 PM, <soja-lists at aries.uberspace.de> wrote:
> Am 2016-03-17 10:46, schrieb Parthiv Parikh:
>> I was getting started with the hello world. I completed all the steps
>> successfully but i seem to have stuck on building the SPARC tool set.
>> I entered the following command "
>> ../source-builder/sb-set-builder --log=l-sparc.txt \
>> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
>> the building went on for a few minutes then it seems to have stuck on
>> "building:
>> sparc-rtems4.12-gcc-6-20160228-newlib-2.3.0.20160226-x86_64-linux-gnu-1
>> I aborted it after around 35 minutes.
> How many cores do you have on your machine? Compiling gcc might take a
> while (even more than an hour).
> If something goes wrong the RSB will usually tell with a build-failed
> message.
> I couldn't see the log file. Maybe it was to large for my mail provider.
> Best regards,
> Jan
> I have attached the log file. Kindly guide me on how I should proceed.
>> Thanks.
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160317/e4a25af4/attachment.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
Command Line: ../source-builder/sb-set-builder --log=l-sparc.txt --prefix=/home/onezero/development/rtems/4.12 4.12/rtems-sparc
Python: 2.7.6 (default, Jun 22 2015, 17:58:13) [GCC 4.8.2]
git://git.rtems.org/rtems-source-builder.git/origin/db8ec8c99e9ac3259c255e04dce9937840a4fd61-modified
Linux Parthiv 4.2.0-27-generic #32~14.04.1-Ubuntu SMP Fri Jan 22 15:32:26 UTC 2016 x86_64
Tail of the build log:
checking whether initstate_r is declared without a macro... yes
checking whether mkdtemp is declared without a macro... yes
checking whether mkostemp is declared without a macro... yes
checking whether mkostemps is declared without a macro... yes
checking whether mkstemp is declared without a macro... yes
checking whether mkstemps is declared without a macro... yes
checking whether posix_openpt is declared without a macro... yes
checking whether ptsname is declared without a macro... yes
checking whether ptsname_r is declared without a macro... yes
checking whether random is declared without a macro... yes
checking whether random_r is declared without a macro... yes
checking whether realpath is declared without a macro... yes
checking whether rpmatch is declared without a macro... yes
checking whether secure_getenv is declared without a macro... yes
checking whether setenv is declared without a macro... yes
checking whether setstate is declared without a macro... yes
checking whether setstate_r is declared without a macro... yes
checking whether srandom is declared without a macro... yes
checking whether srandom_r is declared without a macro... yes
checking whether strtod is declared without a macro... yes
checking whether strtoll is declared without a macro... yes
checking whether strtoull is declared without a macro... yes
checking whether unlockpt is declared without a macro... yes
checking whether unsetenv is declared without a macro... yes
checking for strchrnul... yes
checking whether strchrnul works... yes
checking whether strstr works in linear time... yes
checking whether strstr works... (cached) yes
checking for strtok_r... yes
checking whether strtok_r works... yes
checking for nlink_t... yes
checking whether fchmodat is declared without a macro... yes
checking whether fstat is declared without a macro... yes
checking whether fstatat is declared without a macro... yes
checking whether futimens is declared without a macro... yes
checking whether lchmod is declared without a macro... yes
checking whether lstat is declared without a macro... yes
checking whether mkdirat is declared without a macro... yes
checking whether mkfifo is declared without a macro... yes
checking whether mkfifoat is declared without a macro... yes
checking whether mknod is declared without a macro... yes
checking whether mknodat is declared without a macro... yes
checking whether stat is declared without a macro... yes
checking whether utimensat is declared without a macro... yes
checking whether chdir is declared without a macro... yes
checking whether chown is declared without a macro... yes
checking whether dup is declared without a macro... yes
checking whether dup2 is declared without a macro... yes
checking whether dup3 is declared without a macro... yes
checking whether environ is declared without a macro... yes
checking whether euidaccess is declared without a macro... yes
checking whether faccessat is declared without a macro... yes
checking whether fchdir is declared without a macro... yes
checking whether fchownat is declared without a macro... yes
checking whether fdatasync is declared without a macro... yes
checking whether fsync is declared without a macro... yes
checking whether ftruncate is declared without a macro... yes
checking whether getcwd is declared without a macro... yes
checking whether getdomainname is declared without a macro... yes
checking whether getdtablesize is declared without a macro... yes
checking whether getgroups is declared without a macro... yes
checking whether gethostname is declared without a macro... yes
checking whether getlogin is declared without a macro... yes
checking whether getlogin_r is declared without a macro... yes
checking whether getpagesize is declared without a macro... yes
checking whether getusershell is declared without a macro... yes
checking whether setusershell is declared without a macro... yes
checking whether endusershell is declared without a macro... yes
checking whether group_member is declared without a macro... yes
checking whether isatty is declared without a macro... yes
checking whether lchown is declared without a macro... yes
checking whether link is declared without a macro... yes
checking whether linkat is declared without a macro... yes
checking whether lseek is declared without a macro... yes
checking whether pipe is declared without a macro... yes
checking whether pipe2 is declared without a macro... yes
checking whether pread is declared without a macro... yes
checking whether pwrite is declared without a macro... yes
checking whether readlink is declared without a macro... yes
checking whether readlinkat is declared without a macro... yes
checking whether rmdir is declared without a macro... yes
checking whether sethostname is declared without a macro... yes
checking whether sleep is declared without a macro... yes
checking whether symlink is declared without a macro... yes
checking whether symlinkat is declared without a macro... yes
checking whether ttyname_r is declared without a macro... yes
checking whether unlink is declared without a macro... yes
checking whether unlinkat is declared without a macro... yes
checking whether usleep is declared without a macro... yes
checking whether btowc is declared without a macro... yes
checking whether wctob is declared without a macro... yes
checking whether mbsinit is declared without a macro... yes
checking whether mbrtowc is declared without a macro... yes
checking whether mbrlen is declared without a macro... yes
checking whether mbsrtowcs is declared without a macro... yes
checking whether mbsnrtowcs is declared without a macro... yes
checking whether wcrtomb is declared without a macro... yes
checking whether wcsrtombs is declared without a macro... yes
checking whether wcsnrtombs is declared without a macro... yes
checking whether wcwidth is declared without a macro... yes
checking whether wmemchr is declared without a macro... yes
checking whether wmemcmp is declared without a macro... yes
checking whether wmemcpy is declared without a macro... yes
checking whether wmemmove is declared without a macro... yes
checking whether wmemset is declared without a macro... yes
checking whether wcslen is declared without a macro... yes
checking whether wcsnlen is declared without a macro... yes
checking whether wcscpy is declared without a macro... yes
checking whether wcpcpy is declared without a macro... yes
checking whether wcsncpy is declared without a macro... yes
checking whether wcpncpy is declared without a macro... yes
checking whether wcscat is declared without a macro... yes
checking whether wcsncat is declared without a macro... yes
checking whether wcscmp is declared without a macro... yes
checking whether wcsncmp is declared without a macro... yes
checking whether wcscasecmp is declared without a macro... yes
checking whether wcsncasecmp is declared without a macro... yes
checking whether wcscoll is declared without a macro... yes
checking whether wcsxfrm is declared without a macro... yes
checking whether wcsdup is declared without a macro... yes
checking whether wcschr is declared without a macro... yes
checking whether wcsrchr is declared without a macro... yes
checking whether wcscspn is declared without a macro... yes
checking whether wcsspn is declared without a macro... yes
checking whether wcspbrk is declared without a macro... yes
checking whether wcsstr is declared without a macro... yes
checking whether wcstok is declared without a macro... yes
checking whether wcswidth is declared without a macro... yes
checking whether iswcntrl works... yes
checking for towlower... yes
checking for wctype_t... yes
checking for wctrans_t... yes
checking whether wctype is declared without a macro... yes
checking whether iswctype is declared without a macro... yes
checking whether wctrans is declared without a macro... yes
checking whether towctrans is declared without a macro... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of /usr/bin/gcc -O2 -pipe -I/home/onezero/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-onezero/4.12/rtems-sparc/home/onezero/development/rtems/4.12/include... gcc3
checking whether ln -s works... yes
checking for x86_64-linux-gnu-ranlib... x86_64-linux-gnu-ranlib
checking for x86_64-linux-gnu-ar... x86_64-linux-gnu-ar
configure: updating cache ./config.cache
configure: creating ./config.status
config.status: creating Makefile
config.status: creating import/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing default commands
checking whether NLS is requested... no
checking whether makeinfo --split-size=5000000 supports @click... yes
checking for default auto-load directory... $debugdir:$datadir/auto-load
checking for default auto-load safe-path... $debugdir:$datadir/auto-load
checking libunwind-ia64.h usability... no
checking libunwind-ia64.h presence... no
checking for libunwind-ia64.h... no
checking for monstartup... yes
checking for _mcleanup... yes
checking for _etext... yes
checking for etext... yes
checking for bison... bison -y
checking for x86_64-linux-gnu-dlltool... dlltool
checking for x86_64-linux-gnu-windres... windres
checking for main in -lm... yes
checking for wctype... yes
checking for library containing gethostbyname... none required
checking for library containing socketpair... none required
checking for library containing kinfo_getvmmap... no
checking for ld used by GCC... x86_64-linux-gnu-ld
checking if the linker (x86_64-linux-gnu-ld) is GNU ld... yes
checking for shared library run path origin... done
checking for iconv... yes
checking for iconv declaration... install-shextern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for library containing waddstr... -lncurses
checking for library containing tgetent... none required
checking size of unsigned long long... 8
checking size of unsigned long... 8
checking size of unsigned __int128... 16
checking for library containing dlopen... (cached) -ldl
checking whether to use expat... yes
checking for libexpat... yes
checking how to link with libexpat... /home/onezero/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-onezero/4.12/rtems-sparc/home/onezero/development/rtems/4.12/lib/libexpat.so -Wl,-rpath -Wl,/home/onezero/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-onezero/4.12/rtems-sparc/home/onezero/development/rtems/4.12/lib
checking for XML_StopParser... yes
checking whether to use python... yes
checking for python... /usr/bin/python
checking for python2.7... no
configure: error: python is missing or unusable
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory `/home/onezero/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex /home/onezero/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/doit
