Help regarding buildin SPARC tool set
soja-lists at aries.uberspace.de soja-lists at aries.uberspace.de
Thu Mar 17 13:02:16 UTC 2016
Am 2016-03-17 13:24, schrieb Parthiv Parikh:
> I ran the command once again and this time i let it build. I got an
> error
> message in the end after 40 minutes.
> "error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
> Build FAILED
>   See error report:
> rsb-report-sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1.txt
> Build Set: Time 0:41:59.278169
> Build FAILED"
> I checked the error report it says "python is missing or unusable". I
> checked through terminal and found that python 2.7 is installed and
> running.
I think there were a couple of threads recently about this problem with
python on Ubuntu.
IIRC the solution was to install the packet python-dev or
libpython2.7-dev.
> I am attaching the error report.
> On Thu, Mar 17, 2016 at 3:33 PM, <soja-lists at aries.uberspace.de> wrote:
>> Am 2016-03-17 10:46, schrieb Parthiv Parikh:
>>> I was getting started with the hello world. I completed all the steps
>>> successfully but i seem to have stuck on building the SPARC tool set.
>>> I entered the following command "
>>> ../source-builder/sb-set-builder --log=l-sparc.txt \
>>> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
>>> the building went on for a few minutes then it seems to have stuck on
>>> "building:
>>> sparc-rtems4.12-gcc-6-20160228-newlib-2.3.0.20160226-x86_64-linux-gnu-1
>>> I aborted it after around 35 minutes.
>> How many cores do you have on your machine? Compiling gcc might take a
>> while (even more than an hour).
>> If something goes wrong the RSB will usually tell with a build-failed
>> message.
>> I couldn't see the log file. Maybe it was to large for my mail
>> provider.
>> Best regards,
>>    Jan
>> I have attached the log file. Kindly guide me on how I should proceed.
>>> Thanks.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
