/bin/bash: no: command not found.
Wang, John (IVV-1800) john.wang-1 at nasa.gov
Fri Mar 18 14:32:56 UTC 2016
So I am compiling for the Leon 3 compiler
The command I am running after the configure is
sudo make all CC=/opt/rtems-4.10/bin/sparc-rtems-gcc
make[7]: Entering directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/cpukit/score/cpu/sparc'
/opt/rtems-4.10/bin/sparc-rtems-gcc -DHAVE_CONFIG_H   -I../../.. -I../../../../cpukit/../../../leon3/lib/include   -mcpu=cypress -msoft-float -O2 -g -Wall -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libscorecpu_a-cpu.o -MD -MP -MF .deps/libscorecpu_a-cpu.Tpo -c -o libscorecpu_a-cpu.o `test -f 'cpu.c' || echo '../../../../../../../../rtems-4.10a/c/src/../../cpukit/score/cpu/sparc/'`cpu.c
mv -f .deps/libscorecpu_a-cpu.Tpo .deps/libscorecpu_a-cpu.Po
/opt/rtems-4.10/bin/sparc-rtems-gcc --pipe -DHAVE_CONFIG_H   -I../../.. -I../../../../cpukit/../../../leon3/lib/include  -DASM -mcpu=cypress -msoft-float -O2 -g -Wall -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -mcpu=cypress -msoft-float -O2 -g -Wall -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libscorecpu_a-cpu_asm.o -MD -MP -MF .deps/libscorecpu_a-cpu_asm.Tpo -c -o libscorecpu_a-cpu_asm.o `test -f 'cpu_asm.S' || echo '../../../../../../../../rtems-4.10a/c/src/../../cpukit/score/cpu/sparc/'`cpu_asm.S
mv -f .deps/libscorecpu_a-cpu_asm.Tpo .deps/libscorecpu_a-cpu_asm.Po
rm -f libscorecpu.a
no cru libscorecpu.a libscorecpu_a-cpu.o libscorecpu_a-cpu_asm.o
make[7]: *** [libscorecpu.a] Error 127
make[7]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/cpukit/score/cpu/sparc'
make[6]: *** [all-recursive] Error 1
make[6]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/cpukit/score/cpu'
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/cpukit/score'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/cpukit'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/cpukit'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c'
make: *** [all-recursive] Error 1
thanks
John
________________________________________
Sent: Thursday, March 17, 2016 6:19 PM
To: Wang, John (IVV-1800); users at rtems.org
Subject: Re: /bin/bash: no: command not found.
[ I removed the devel list to avoid cross posting.
   This is a user question and not an RTEMS developer question. ]
On 18/03/2016 07:28, Wang, John (IVV-1800) wrote:
> *So I got much further with make.  Now I have the following errors:*
> no cru libscorecup.a libscorecup_a-cpu.o libscorecpu_a-cp_asm.o
> Can anyone shed some light on this?
Can you please provide some more detail? Maybe the last part of the
output with the error, your host and the command you entered?
Thanks
