Beaglebone
Angelo Fraietta
newsgroups at smartcontroller.com.au
Wed Mar 23 21:03:03 UTC 2016
That is great to hear. A while ago, I posted an issue I had with memory
allocation back in October and never heard anything back - this is it. Do
you know if it is fixed?
Greetings
I am trying to call some C++ code from my C module using extern C.
The code compiles fine, however, without even calling the function, If I
add a call to a new class, the program crashes and reboots. If I comment
out the call as per below, program works fine
extern "C" void createNewClass()
// uncomment below and will crash program when it runs
//newClass *class_ptr = new newClass();
Has anyone tested c++ code with operator new on Beaglebone black?
Thanks
On Thu, Mar 24, 2016 at 7:29 AM, Matias Bueno <
matias.bueno at tallertechnologies.com> wrote:
> What is the status of the Beaglebone black BSP?
> Hi Angelo!
> You can find information about Beaglebone dev status at:
> https://devel.rtems.org/wiki/TBR/BSP/Beagleboard
> And some gaps and pending development at:
> https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP
> Our experience:
> We at Taller Technologies set up and used Beaglebone Black for a client’s
> project with good level of success.
> The client uses it for various functionalities in the air (serial, USB,
> CANAS, GPIO, I2C, RTC), in ground station (serial, network) and in lab for
> testing purposes (serial, network).
> In our way we found and fix several bugs that we contributed and are
> integrated in the BSP.
> As a note of its potential: on top of the existing BSP we worked for this
> client on:
> I2C: We used Texas Instruments’ baremetal Starterware* driver,
> adapting it to RTEMS. In this year’s GSoC there is a project to contribute
> I2C and PWM drivers, which we’re mentoring.
> RTC: We managed a DS1307 RTC through I2C.
> USB: Adapted from the baremetal of Starterware* to RTEMS.
> Ethernet & LWIP: We ported and adapted the LWIP stack from
> Starterware* baremetal to be aware of RTEMS threads and message queues.
> This was contributed as a separate library with the rtems source builder.
> GPIO: ported and adapted Starterware* drivers.
> CAN: ported and adapted Starterware* drivers.
> Interrupt controller: Fixed a bug that affected many other modules.
> * Adapting, Correcting a Using Starterware drivers: due to licensing
> issues we cannot contribute that code to the community (Starterware has an
> incompatible license). In all those cases we can re-work the drivers in
> order to be able to contribute them. As soon as we find a new client willing
> to fund such project we can contribute the resulting work.
> Let me know if we can help you any further.
> Regards,
> Matias
> On Thu, Mar 17, 2016 at 7:56 PM Angelo Fraietta <
> newsgroups at smartcontroller.com.au> wrote:
>> Greetings
>> Thanks
>> users mailing list
>> users at rtems.org
> Matias Bueno
> Program Manager
> San Lorenzo 47, 3rd Floor, Office 5 Córdoba, Argentina
> Phone: +54 351 4217888 / +54 351 4218211
> Skype: matiasbueno
URL: <http://lists.rtems.org/pipermail/users/attachments/20160324/9b02b174/attachment.html>
