rsb for arm
D Peter Siddons siddons at bnl.gov
Thu Mar 24 13:45:45 UTC 2016
Hi Matt,
    I'm running gcc 5.2.1.
Pete.
On 03/24/2016 09:36 AM, Matthew Clark wrote:
> I ran into this problem myself.  Basically, the macro that determines
> the GCC version isn't working correctly, so it's defining those
> functions twice.  Are you running GCC 5.x?  I had to comment out the
> code for if the GCC version < 3.0.   It's kind of a pain because it
> means you'll bludgeon the build process as re-running the
> source-builder process will just blow out the old build folder,
> extract the code fresh and you'll have the same problem.
> Matt
> On Thu, Mar 17, 2016 at 9:55 AM, D Peter Siddons <siddons at bnl.gov> wrote:
>> Hi Chris,
>> I searched l-arm.txt for ": error" and found the lines in the attached file.
>> Hope that helps.
>>    I remember seeing something some time ago with Ubuntu. They link /bin/sh
>> to /bin/dash instead of /bin/bash. I'm nervous about changing that in case
>> the system relies on dash-like behaviour, but I do remember that giving
>> mysterious problems once.
>> Pete.
>> On 03/16/2016 10:14 PM, Chris Johns wrote:
>>> On 17/03/2016 12:42, D Peter Siddons wrote:
>>>>     Recently upgraded from 15.04 to 15.10.
>>> Ok.
>>>> Report attached.
>>> Hmm the error was before the report log. I never expected these level of
>>> warnings but building old compilers with newer ones can do this.
>>> I will try and recreate the build.
>>> Any chance you could peak in the log file and cut and paste the error?
>>> Thanks
>>> Chris
>> D. Peter Siddons
>> Detector Development Group Leader
>> Bldg. 535B
>> Photon Sciences Directorate,
>> Brookhaven National Laboratory
>> Upton, NY 11973
>> email: siddons at bnl.gov
>> Phone: (631) 344-2738
>> users mailing list
>> users at rtems.org
D. Peter Siddons
Bldg. 535B
Upton, NY 11973
