rsb for arm
Matthew Clark
linux.matthew at gmail.com
Thu Mar 24 13:36:22 UTC 2016
I ran into this problem myself. Basically, the macro that determines
the GCC version isn't working correctly, so it's defining those
functions twice. Are you running GCC 5.x? I had to comment out the
code for if the GCC version < 3.0. It's kind of a pain because it
means you'll bludgeon the build process as re-running the
source-builder process will just blow out the old build folder,
extract the code fresh and you'll have the same problem.
Matt
On Thu, Mar 17, 2016 at 9:55 AM, D Peter Siddons <siddons at bnl.gov> wrote:
> Hi Chris,
> I searched l-arm.txt for ": error" and found the lines in the attached file.
> Hope that helps.
> I remember seeing something some time ago with Ubuntu. They link /bin/sh
> to /bin/dash instead of /bin/bash. I'm nervous about changing that in case
> the system relies on dash-like behaviour, but I do remember that giving
> mysterious problems once.
> Pete.
> On 03/16/2016 10:14 PM, Chris Johns wrote:
>> On 17/03/2016 12:42, D Peter Siddons wrote:
>>> Recently upgraded from 15.04 to 15.10.
>> Ok.
>>> Report attached.
>> Hmm the error was before the report log. I never expected these level of
>> warnings but building old compilers with newer ones can do this.
>> I will try and recreate the build.
>> Any chance you could peak in the log file and cut and paste the error?
>> Thanks
>> Chris
> D. Peter Siddons
> Detector Development Group Leader
> Bldg. 535B
> Photon Sciences Directorate,
> Brookhaven National Laboratory
> Upton, NY 11973
> email: siddons at bnl.gov
> Phone: (631) 344-2738
> users mailing list
> users at rtems.org
