rsb for arm
D Peter Siddons
siddons at bnl.gov
Thu Mar 24 14:16:05 UTC 2016
Presumably so. It is Ubuntu 15.10.
Pete.
On 03/24/2016 10:07 AM, Joel Sherrill wrote:
> Is it being built with -Werror?
> FWIW I don't see gcc 5.2.1 as an official release. I see 5.2 and 5.3.
> Is that
> other digit from the distribution?
> --joel
> On Thu, Mar 24, 2016 at 8:45 AM, D Peter Siddons <siddons at bnl.gov
> <mailto:siddons at bnl.gov>> wrote:
> Hi Matt,
> I'm running gcc 5.2.1.
> Pete.
> On 03/24/2016 09:36 AM, Matthew Clark wrote:
> I ran into this problem myself. Basically, the macro that
> determines
> the GCC version isn't working correctly, so it's defining those
> functions twice. Are you running GCC 5.x? I had to comment
> out the
> code for if the GCC version < 3.0. It's kind of a pain
> because it
> means you'll bludgeon the build process as re-running the
> source-builder process will just blow out the old build folder,
> extract the code fresh and you'll have the same problem.
> Matt
> On Thu, Mar 17, 2016 at 9:55 AM, D Peter Siddons
> <siddons at bnl.gov <mailto:siddons at bnl.gov>> wrote:
> Hi Chris,
> I searched l-arm.txt for ": error" and found the lines in
> the attached file.
> Hope that helps.
> I remember seeing something some time ago with Ubuntu.
> They link /bin/sh
> to /bin/dash instead of /bin/bash. I'm nervous about
> changing that in case
> the system relies on dash-like behaviour, but I do
> remember that giving
> mysterious problems once.
> Pete.
> On 03/16/2016 10:14 PM, Chris Johns wrote:
> On 17/03/2016 12:42, D Peter Siddons wrote:
> Recently upgraded from 15.04 to 15.10.
> Ok.
> Report attached.
> Hmm the error was before the report log. I never
> expected these level of
> warnings but building old compilers with newer ones
> can do this.
> I will try and recreate the build.
> Any chance you could peak in the log file and cut and
> paste the error?
> Thanks
> Chris
> D. Peter Siddons
> Detector Development Group Leader
> Bldg. 535B
> Photon Sciences Directorate,
> Brookhaven National Laboratory
> Upton, NY 11973
> email: siddons at bnl.gov <mailto:siddons at bnl.gov>
> Phone: (631) 344-2738 <tel:%28631%29%20344-2738>
> users mailing list
> users at rtems.org <mailto:users at rtems.org>
> D. Peter Siddons
> Bldg. 535B
> Upton, NY 11973
> users mailing list
D. Peter Siddons
Bldg. 535B
Upton, NY 11973
URL: <http://lists.rtems.org/pipermail/users/attachments/20160324/f0ddd4a3/attachment-0001.html>
