rsb for arm
Joel Sherrill
joel at rtems.org
Thu Mar 24 14:47:14 UTC 2016
On Thu, Mar 24, 2016 at 9:16 AM, D Peter Siddons <siddons at bnl.gov> wrote:
> Presumably so. It is Ubuntu 15.10.
Unless someone else remembers how, we will have to wait for Chris to wake
up.
But I think adding -Wno-error to the build is the first work-around.
The long term solution will be to patch the older gcc source to avoid the
warning.
I am sure somewhere in the gcc repository is a patch to do that.
--joel
> Pete.
> On 03/24/2016 10:07 AM, Joel Sherrill wrote:
> Is it being built with -Werror?
> FWIW I don't see gcc 5.2.1 as an official release. I see 5.2 and 5.3. Is
> that
> other digit from the distribution?
> --joel
> On Thu, Mar 24, 2016 at 8:45 AM, D Peter Siddons <siddons at bnl.gov> wrote:
>> Hi Matt,
>> I'm running gcc 5.2.1.
>> Pete.
>> On 03/24/2016 09:36 AM, Matthew Clark wrote:
>>> I ran into this problem myself. Basically, the macro that determines
>>> the GCC version isn't working correctly, so it's defining those
>>> functions twice. Are you running GCC 5.x? I had to comment out the
>>> code for if the GCC version < 3.0. It's kind of a pain because it
>>> means you'll bludgeon the build process as re-running the
>>> source-builder process will just blow out the old build folder,
>>> extract the code fresh and you'll have the same problem.
>>> Matt
>>> On Thu, Mar 17, 2016 at 9:55 AM, D Peter Siddons < <siddons at bnl.gov>
>>>> Hi Chris,
>>>> I searched l-arm.txt for ": error" and found the lines in the attached
>>>> file.
>>>> Hope that helps.
>>>> I remember seeing something some time ago with Ubuntu. They link
>>>> /bin/sh
>>>> to /bin/dash instead of /bin/bash. I'm nervous about changing that in
>>>> case
>>>> the system relies on dash-like behaviour, but I do remember that giving
>>>> mysterious problems once.
>>>> Pete.
>>>> On 03/16/2016 10:14 PM, Chris Johns wrote:
>>>>> On 17/03/2016 12:42, D Peter Siddons wrote:
>>>>>> Recently upgraded from 15.04 to 15.10.
>>>>> Ok.
>>>>> Report attached.
>>>>> Hmm the error was before the report log. I never expected these level
>>>>> of
>>>>> warnings but building old compilers with newer ones can do this.
>>>>> I will try and recreate the build.
>>>>> Any chance you could peak in the log file and cut and paste the error?
>>>>> Thanks
>>>>> Chris
>>>> D. Peter Siddons
>>>> Detector Development Group Leader
>>>> Bldg. 535B
>>>> Photon Sciences Directorate,
>>>> Brookhaven National Laboratory
>>>> Upton, NY 11973
>>>> email: siddons at bnl.gov
>>>> Phone: (631) 344-2738 <%28631%29%20344-2738>
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>> D. Peter Siddons
>> Bldg. 535B
>> Upton, NY 11973
>> users mailing list
>> users at rtems.org
> D. Peter Siddons
> Bldg. 535B
> Upton, NY 11973
URL: <http://lists.rtems.org/pipermail/users/attachments/20160324/2675b181/attachment.html>
