RSB for building 4.10
Wang, John (IVV-1800) john.wang-1 at nasa.gov
Thu Mar 24 19:24:19 UTC 2016
Matt,
I tried what you suggested, and I am still getting the same error.
reporting: tools/rtems-gdb-7.3.1-1.cfg -> sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1.txt
reporting: tools/rtems-gdb-7.3.1-1.cfg -> sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1.xml
config: tools/rtems-kernel-4.10.2.cfg
package: sparc-rtems4.10-kernel-4.12 (29819a271950)-1
download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12 -> sources/rtems-4.12 (29819a271950).tar.bz2
download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12: error: <urlopen error ftp error: [Errno ftp error] 550 Failed to change directory.>
error: downloading (29819a271950).tar.bz2: all paths have failed, giving up
Build FAILED
  See error report: rsb-report-sparc-rtems4.10-kernel-4.12 (29819a271950)-1.txt
cleaning: expat-2.1.0-i686-linux-gnu-1
cleaning: sparc-rtems4.10-binutils-2.20.1-i686-linux-gnu-1
cleaning: sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-i686-linux-gnu-1
cleaning: sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1
Build Set: Time 0:46:45.737004
________________________________________
Sent: Thursday, March 24, 2016 12:56 PM
To: Wang, John (IVV-1800)
Cc: rtems-users at rtems.org
Subject: Re: RSB for building 4.10
I ran into this too.  Adding "--keep-going" to the switch let me
continue building and I seemed to have all the tools I expected.  But
it is an odd error.
Matt
On Thu, Mar 24, 2016 at 10:12 AM, Wang, John (IVV-1800)
<john.wang-1 at nasa.gov> wrote:
> When I use RSB to build rtems 4.10, I receive the following errors:
> Build FAILED
> Build Set: Time 0:44:43.317250
> Build FAILED
> Is there something going on with the ftp site?
> thanks
> John
> users mailing list
> users at rtems.org
