Zynq : Manual debugging of an RTEMS demo
Badr El Hiouel
elh.badr at gmail.com
Fri Mar 25 15:43:04 UTC 2016
Hi Chris ,
I did the 'si' and more break points , and now I can see why it never stops
Breakpoint 7, arm_cp15_start_setup_translation_table (ttb=<optimized out>,
client_domain=15, config_table=0x104348 <zynq_mmu_config_table>,
config_count=14) at
../../../../../.././xilinx_zynq_zedboard/lib/include/bsp/arm-cp15-start.h:133
133 for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
Breakpoint 8, arm_cp15_start_setup_translation_table (ttb=<optimized out>,
config_count=14) at
../../../../../.././xilinx_zynq_zedboard/lib/include/bsp/arm-cp15-start.h:134
134 ttb [i] = 0;
I checked the file arm-cp15-start.h and the debugger is stuck in this loop.
When entering 'si' the gdb never stops on executing lines 133 then 134 then
133 again ...
I don't know why it never stops in this loop.
That explains why it never stops. But , I looked for this problem on the
internet and nobody is talking about this.
________
*Badr EL HIOUEL*
Mail : elh.badr at gmail.com
2016-03-25 9:59 GMT+01:00 Badr El Hiouel <elh.badr at gmail.com>:
> Hi Chris ,
> > Did XMD produce any output that indicates a problem? Please make sure
> XMD has not crashed. I have seen it crash in the past, however that was a
> while ago on an old SDK.
> > Maybe set a few other breakpoints. I would set breakpoints on bootcard
> and Init.
> XMD has not crashed and there was any output that indicates a problem. I
> did this operation many times.
> > If you have debugging info you should see the assembler source code for
> start.S and so you should be able to step it. If you see the source code
> try 's' or 'si'.
> Yes, i can see the source code of the start.S, I re-did this operation
> this morning again, and instead of doing cont I did next to debug the code
> line per line. And everything went fine until the line code of the start.S
> b bsp_start_hook_0
> After I did next and it never stops. I think the problem is in this
> branch .. But what is the functionnality of this ? and where I can find
> this function ?
> > I assume there is no watchdog hardware running?
> I don't know how can I check if the watchdog is running or not. What can
> be the impact of the watchdog ?
> > I have never used XMD but I know users have. I have been using OpenOCD.
> I read papers you wrote about this technique. To perform it, we have to
> get other tools (than the tools of the kit )
> > Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20160325/38fd2ab7/attachment.html>
