RSB for building 4.10
Fri Mar 25 22:00:46 UTC 2016
On 26/03/2016 2:30 AM, Wang, John (IVV-1800) wrote:
> Still receiving the same error.
> reporting: tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg -> sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-i686-linux-gnu-1.txt
> reporting: tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg -> sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-i686-linux-gnu-1.xml
> config: tools/rtems-gdb-7.3.1-1.cfg
> package: sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1
> warning: gdb-7.3.1.tar.gz: no hash found
> building: sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1
> reporting: tools/rtems-gdb-7.3.1-1.cfg -> sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1.txt
> reporting: tools/rtems-gdb-7.3.1-1.cfg -> sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1.xml
> config: tools/rtems-kernel-4.10.2.cfg
> package: sparc-rtems4.10-kernel-4.12 (29819a271950)-1
> download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12 -> sources/rtems-4.12 (29819a271950).tar.bz2
> download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12: error: <urlopen error ftp error: [Errno ftp error] 550 Failed to change directory.>
> error: downloading (29819a271950).tar.bz2: all paths have failed, giving up
> Build FAILED
>    See error report: rsb-report-sparc-rtems4.10-kernel-4.12 (29819a271950)-1.txt
> Build Set: Time 0:41:40.693626
> Build FAILED
> Below is the command I used
Thanks. I will need to take a look. It will be a few days before I have time.
> sudo ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/4.10 4.10/rtems-sparc --rtems-version=4.10
FYI https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html#adminisrator-access
