RTEMS 4.11 build fails for sparc-leon3 with multilib enabled
Thibaud Backenstrass
thibaud.backenstrass at phelma.grenoble-inp.fr
Thu Mar 31 20:06:27 UTC 2016
*Thibaud BACKENSTRASS*
*Élève-ingénieur - Grenoble INP-Phelma - 3A SLE*
E-mail : thibaud.backenstrass at phelma.grenoble-inp.fr
Hello,
I recently tried to build RTEMS with multilib enabled in order to install a
GNAT Ada toolset [1]. However, the compilation failed with the error :
../../lib/include/pci/access.h:17:30: fatal error: libcpu/byteorder.h: No
such file or directory
The same problem has already been mentionned last year [2], but no solution
was given. I've tried with the version of RTEMS sources available on
Github, on branch 4.11, but also with the version 4.11.0-rc3 published on
ftp.rtems.org, but both raised the same error. Moreover, I have run the
bootstrap script right before trying to build. Any help would be highly
appreciate!
I'm working with Debian 8.3 Jessie and I used RSB to install the C/C++
cross compiler for Leon3. Here are some additional information about my
configuration:
$ sparc-rtems4.11-gcc --version -v
sparc-rtems4.11-gcc (GCC) 4.9.3 20150626 (RTEMS 4.11, RSB no-repo, Newlib
2.2.0.20150423)
Target: sparc-rtems4.11
Configured with: ../gcc-4.9.3/configure
--prefix=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools
--bindir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/bin
--exec_prefix=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools
--includedir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/include
--libdir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/lib
--libexecdir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/libexec
--mandir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/share/man
--infodir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/share/info
--datadir=/home/thibaud/Etudes/Ensimag3A/rtems/4.11.0-rc3/tools/share
--build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=sparc-rtems4.11
--disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose --with-newlib
--with-system-zlib --disable-nls --without-included-gettext
--disable-win32-registry --enable-version-specific-runtime-libs
--disable-lto --enable-newlib-io-c99-formats --enable-newlib-iconv
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
--enable-threads --disable-plugin --enable-libgomp --enable-languages=c,c++
Options given to build RTEMS:
../rtems-4.11.0-rc3/configure --prefix=$RTEMS --target=sparc-rtems4.11
--enable-rtemsbsp=leon3 --enable-tests --enable-multilib --enable-cxx
--enable-posix --enable-networking
Options given to RSB (RTEMS Source Builder), I used the version available
in the directory 4.11.0-rc3 on ftp.rtems.org):
../source-builder/sb-set-builder --log=sparc.log --prefix=$RTEMS/tools
4.11/rtems-sparc
References:
[1] See comment in gcc/ada/gsocket.h, in gcc sources.
[2] https://lists.rtems.org/pipermail/users/2015-April/028751.html
Best regards,
*Thibaud*
URL: <http://lists.rtems.org/pipermail/users/attachments/20160331/59ebd5a3/attachment-0001.html>
