RSB Mac 4.11 broken
Mr. Andrei Chichak groups at chichak.ca
Thu Mar 3 21:33:45 UTC 2016
I’m really sorry to have to bring this up but the Mac RSB is broken due to a missing diff file for automake at RedHat.
I’m using this as an install script:
cd
mkdir -p development/rtems/src
cd development/rtems/src
git clone git://git.rtems.org/rtems-source-builder.git <git://git.rtems.org/rtems-source-builder.git>
cd rtems-source-builder
source-builder/sb-check
cd rtems
../source-builder/sb-set-builder --list-bsets
../source-builder/sb-set-builder --log=l-arm.txt --prefix=$HOME/development/rtems/4.11 4.11/rtems-arm
git clone git://git.rtems.org/rtems.git <git://git.rtems.org/rtems.git>
cd ~/development
./buildrtems
And the important bit happens quite early:
    rtems-base.bset
    rtems-urls.bset
RTEMS Source Builder - Set Builder, 4.12 (b537e5536459 modified)
Build Set: 4.11/rtems-arm
Build Set: 4.11/rtems-autotools.bset
Build Set: 4.11/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-apple-darwin15.3.0-1
Creating source directory: sources
download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz <ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz> -> sources/autoconf-2.69.tar.gz
downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
building: autoconf-2.69-x86_64-apple-darwin15.3.0-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-apple-darwin15.3.0-1
download: ftp://ftp.gnu.org/gnu/automake/automake-1.12.6.tar.gz <ftp://ftp.gnu.org/gnu/automake/automake-1.12.6.tar.gz> -> sources/automake-1.12.6.tar.gz
downloading: sources/automake-1.12.6.tar.gz - 2.0MB of 2.0MB (100%)
Creating source directory: patches
download: https://git.rtems.org/rtems-tools/plain/tools/4.11/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff <https://git.rtems.org/rtems-tools/plain/tools/4.11/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff> -> patches/automake-1.12.6-bugzilla.redhat.com <http://automake-1.12.6-bugzilla.redhat.com/>-1239379.diff
download: https://git.rtems.org/rtems-tools/plain/tools/4.11/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff: <https://git.rtems.org/rtems-tools/plain/tools/4.11/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff:> error: HTTP Error 404: Not found
error: downloading https://git.rtems.org/rtems-tools/plain/tools/4.11/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff: <https://git.rtems.org/rtems-tools/plain/tools/4.11/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff:> all paths have failed, giving up
Build FAILED
  See error report: rsb-report-automake-1.12.6-x86_64-apple-darwin15.3.0-1.txt
Build Set: Time 0:00:23.276118
Build Set: Time 0:00:23.363103
Build Set: Time 0:00:23.374966
Build FAILED
Thanks for all of your good work,
Andrei (from The Great White North)
www.embedded.fm/blog <http://www.embedded.fm/blog>
URL: <http://lists.rtems.org/pipermail/users/attachments/20160303/c58f51e9/attachment-0002.html>
