rsb for arm
    Chris Johns
    chrisj at rtems.org
    Wed Mar 16 05:39:10 UTC 2016
On 16/03/2016 12:06, D Peter Siddons wrote:
> I tried to use rsb to build rtems-arm 4.10 on a Kubuntu 15.10 system.
New system or one you have used before?
> Doing the system check shows OK:
> peter:~/development/rtems/src/rtems-source-builder$ source-builder/sb-check
> RTEMS Source Builder - Check, 4.12 (276fdc488e4b)
> Environment is ok
> Build went OK until:
> config: tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
> package: arm-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1
> building: arm-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1
> error: building arm-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1
> Build FAILED
>    See error report:
> rsb-report-arm-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1.txt
> Build Set: Time 0:03:27.146774
> Build FAILED
> I am attaching the log file. Anyone know what is wrong?
Could you please attach the report file. The attached file is the
sb-check's log file.
Thanks.
