RTEMS ARMv8 Port
Raghav Nayak raghav.nayak at nxp.com
Wed Mar 16 13:54:03 UTC 2016
Gedare,
Currently I have put necessary port for ARMv8 to run "HelloWorld" App. But hitting some issue while linking final hello app
With Regards
  Raghav
-----Original Message-----
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
Sent: Wednesday, March 16, 2016 7:22 PM
To: Raghav Nayak
Cc: joel at rtems.org; Jan Sommer; rtems-users at rtems.org
Subject: Re: RTEMS ARMv8 Port
Raghav,
In addition to the RTEMS toolchain, you must have a port of RTEMS itself to the target architecture. This involves probably a week or two of engineering effort.
On Wed, Mar 16, 2016 at 9:48 AM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
> Hi Joel,
> Currently I am using the RTEMS toolchain for ARMv8 through Source
> Builder
> With Regards
> Raghav
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Raghav Nayak
> Sent: Wednesday, March 16, 2016 6:51 PM
> To: joel at rtems.org; Jan Sommer
> Cc: rtems-users at rtems.org
> Subject: RE: RTEMS ARMv8 Port
> Hi Joel,
> I could build to some extent and when it comes to application it says
> “error: Cannot change output format whilst linking AArch64 binaries”.
> Any hints to resolve this problem ? Thanks
> With Regards
>   Raghav
> From: Joel Sherrill [mailto:joel at rtems.org]
> Sent: Wednesday, March 16, 2016 6:05 PM
> To: Jan Sommer
> Cc: rtems-users at rtems.org; Raghav Nayak
> On Mar 16, 2016 7:26 AM, <soja-lists at aries.uberspace.de> wrote:
>> Am 2016-03-16 10:32, schrieb Raghav Nayak:
>>> Hi,
>>> I am trying to configure RTEMS for ARMv8 target. Tried running the
>>> following command:
>>> ../configure --target=aarch64-rtems4.12
>>> --enable-rtemsbsp=raspberrypi --enable-tests=samples
>>> --enable-networking --enable-posix
>>> --prefix=/mnt/FSL/pandora/rtems/rtems-armv8-bsp/4.12
>> I am no expert in this, but I highly doubt that this is supposed to work.
>> So far you only have a cross-compiler for RTEMS for the aarch64 target.
>> However, as ARMv8 is a new architecture for RTEMS I would expect that
>> you need to first add support for this new architecture to the
>> RTEMS-kernel and probably the configure scripts as well. I have never
>> done this, so I can't help here. The RTEMS porting guide might be a
>> first step in understanding what you have to do:
>> https://docs.rtems.org/doc-current/share/rtems/pdf/porting.pdf
>> Another thing is that you want to build the raspberrypi-bsp. I assume
>> you want to build RTEMS for the raspberry pi 3. The new raspberry
>> uses another cpu as the older versions and of a different target
>> architecture. That means from the operating system's point of view it
>> differs significantly from the older ones, thus you cannot expect
>> that the bsp for the RPi 1 and RPi 2 will work for the RPi 3.
>> No one has added support for the RPi 3 yet. It's very new on the
>> market and RTEMS has currently no ARMv8 support.
> That's the basics. A new architecture requires adding
> score/cpu/aarch64 and a new BSP for that architecture
> c/src/lib/libbsp/aarch64/NEWBSP. I added the GNU tools support.
> I did notice that gdb has a simulator for aarch64 which means a BSP
> for that is simple to construct. The gdb simulator is similar on all
> architectures and we have BSPs for a variety to use as examples. This
> would be enough to debug core functionality on the aarch64 and run the
> tests without interrupt support.
> Then you have to add interrupt support and move to real HW and add a
> second BSP.
>>> But not able to get the output something like this:
>>> target architecture: aarch64.
>>> available BSPs: raspberrypi.
>>> 'make all' will build the following BSPs: raspberrypi.
>>> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
>>> config.status: creating Makefile
>>> Do you have any clues?
>>> With Regards
>>>   Raghav
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
