Workflow RTEMS on Zynq Zedboard
Badr El Hiouel
elh.badr at gmail.com
Tue Mar 22 10:32:53 UTC 2016
I'm a little bit confusing.
So, if I understand, The 1st part of the workflow ( ie building the RSB &
generating the rtems bsp ) is only for compiling programs ( with as a
target arm architectures ). This means , every time I have to launch an
RTEMS program I have to recompile the program ( the part after ./bootstrap
in the workflow ) ?
I Tought , the bsps we generate can be used like in this video i found ( it
is for µC/OS II on Zynq ) : https://www.youtube.com/watch?v=omB7qVBQaIM
Please can anybody else confirm that or give us a clarification.
Thank you
________
*Badr EL HIOUEL*
Mail : elh.badr at gmail.com
2016-03-22 11:16 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
> Am 2016-03-22 09:45, schrieb Badr El Hiouel:
>> Hi Jan ,
>> Thank you for support.
>> It finally success! For that , I had to delete all the project, then I
>> rebuild RSB and then it went very fine.
>> Now , I designed a Zynq HW on Vivado and I launched it on SDK. But now ,
>> in
>> the labs ( you sent me one for the µZed , The same exists for Zedboard )
>> they create a new bsp. I imagine that in this step I don't have to create
>> one but import it from the rtems.
>> This part is a bit tricky. The term "bsp" is used in 2 different contexts
> here.
> First you have the rtems-bsp. That complements the generic parts of rtems
> with the things that depend on your intended target platform (i.e.
> Zedboard) like drivers for the global timer, etc. This generates the
> rtems-library for your platform which is linked to your application code to
> create your RTEMS-application (e.g. ticker.exe).
> Then you have the bsp in the Xilinx context. The Zync CPU consists of an
> ARM-CPU and an FPGA. In order to run any application on the CPU you also
> have to configure the FPGA, which you do with the bsp and the FSBL from the
> Xilinx-toolchain.
> I don't know too much about that configuration so far. I simply followed
> the tutorial where the FPGA is mainly responsible to connect the CPU to the
> RAM.
> In part 4 of the Tutorial for the MicroZed they build a boot image. If you
> take a look at Figure 6 (p. 7), I simply replaced the Periph_Test.elf with
> the test program generated by RTEMS and continued. The setup for the normal
> Zedboard should be pretty similar. The resulting boot image will boot,
> initialize the FPGA, load the RTEMS program into RAM and transfer control
> to it.
> So, where I find the bsp ? It's a single file or a directory ? And then how
>> can I to import it on SDK ?
>> I read also that for ticker.exe we have to change the extension for .elfe
>> is that what I'll have to do ?
>> It might be that the file dialog of the Xilinx tools expects *.elf-files,
> so renaming might be necessary.
> Best regards,
> Jan
> PS: Please keep the rtems-users list as recipient, so other people might
> join the discussion and people with the same problem might benefit.
> Thank you!
>> ________
>> *Badr EL HIOUEL*
>> 2016-03-19 11:57 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>> Am Friday 18 March 2016, 17:24:48 schrieb Badr El Hiouel:
>>> > > Thank you for your support,
>>> > > I installed the devel environnement for Python27 and it builds (
>>> finally !
>>> > > When I did :
>>> > > /mnt/D/development/rtems/kernel/rtems/configure
>>> --target=arm-rtems4.12
>>> > > --enable-rtemsbsp=xilinx_zynq_zedboard --enable-tests=samples
>>> > > --enable-posix --enable-cxx
>>> --prefix=/mnt/D/development/rtems/bsps/4.12
>>> > > BSP_ARM_A9MPCORE_PERIPHCLK=333333333U
>>> > > It worked but when running make && make install it shows me an error
>>> > > checking for RTEMS_CPU_MODEL...
>>> > > checking for RTEMS_BSP_FAMILY... xilinx-zynq
>>> > > checking for CPU_CFLAGS... (cached) -march=armv7-a -mthumb -mfpu=neon
>>> > > -mfloat-abi=hard -mtune=cortex-a9
>>> > > checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g -ffunction-sections
>>> > > -fdata-sections
>>> > > checking for style of include used by gmake... GNU
>>> > > checking for arm-rtems4.12-gcc... no
>>> > > configure: error: no acceptable cc found in $PATH
>>> > > gmake[2]: *** [xilinx_zynq_zedboard] Error 1
>>> > > gmake[2]: Leaving directory
>>> > > `/mnt/D/development/rtems/kernel/zynq/arm-rtems4.12/c'
>>> > > gmake[1]: *** [all-recursive] Error 1
>>> > > gmake[1]: Leaving directory
>>> > > make: *** [all-recursive] Error 1
>>> So if I understand it correctly, the RSB finished sucessfully? Then you
>>> should have binaries like arm-rtems-4.12-* installed to the directory you
>>> passed to the RSB.
>>> Configure complains that it cannot find said binaries. That is probably
>>> because you haven't added them to your PATH environment variable.
>>> You can do that with (use the correct path to the bin-directory of your
>>> setup)
>>> export PATH=/mnt/D/development/rtems/compiler/4.12/bin:$PATH
>>> Try the configure command again after that.
>>> > > It's a problem of directories ? or the configuration I did ? ( I took
>>> the
>>> > > same configuration you did Jan , because I have no ideas what is
>>> those
>>> > > configurations and how to choose that if any body has an explanation
>>> for
>>> > > this part)
>>> The configure command is part of the autotools and very common in the
>>> Linux/Unix world when building programs from source.
>>> It checks if all the dependencies are met before you build it and gives
>>> you the ability to configure which features of the program you want to
>>> enable and where to install it.
>>> > > Thank you
>>> > > ________
>>> > > *Badr EL HIOUEL*
>>> > > 2016-03-17 23:16 GMT+01:00 Chris Johns <chrisj at rtems.org>:
>>> > >> On 18/03/2016 03:12, Jan Sommer wrote:
>>> > >>> Am 2016-03-17 16:31, schrieb Badr El Hiouel:
>>> > >>>> I had this error that I can't found anywhere the solution for it.
>>> I
>>> > >>>> attached the report bug .. Can you please tell me what is going
>>> wrong ?
>>> > >>> It seems to be the same error which occurs quite often here
>>> recently.
>>> > >>> Apparently you need to install the python-development packet.
>>> > >>> On a debian based distro it should be python-dev or
>>> libpython2.7-dev
>>> > >> I have added a note about this in the up coming Getting Started
>>> Guide:
>>> https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html#development-version
>>> > >> It is difficult for the RSB to track dependences for packages like
>>> this.
>>> > >> There are plans but they have not been implemented.
>>> > >> Chris
>>> > >> _______________________________________________
>>> > >> users mailing list
>>> > >> users at rtems.org
>>> > >> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160322/45479c40/attachment-0002.html>
