Workflow RTEMS on Zynq Zedboard
Badr El Hiouel elh.badr at gmail.com
Tue Mar 22 11:33:14 UTC 2016
Ok, Thank you.
I'm understanding now.
I can't find details for the importing part of the ticker.exe program. ( in
the labs they create a new application project - in other labs they copy an
file.c )
How did you import the ticker.exe ?
________
*Badr EL HIOUEL*
Mail : elh.badr at gmail.com
2016-03-22 12:06 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
> Am 2016-03-22 11:32, schrieb Badr El Hiouel:
>> I'm a little bit confusing.
>> So, if I understand, The 1st part of the workflow ( ie building the RSB &
>> generating the rtems bsp ) is only for compiling programs ( with as a
>> target arm architectures ).
> It generates the toolchain for compiling programs, i.e. compiler, linker,
> RTEMS libraries.
> You then write your application code, with tasks, I/O and compile it with
> this toolchain.
> For example ticker is such an application. It will be compiled and linked
> with arm-rtems4.xx-gcc and the result will be your binary ticker.exe, which
> you then have to load to your target platform.
> For simpler boards like the raspberry pi you only have to copy the binary
> file to the sd-card. For the Zedboard you also have to include a setup for
> the FPGA.
> This means , every time I have to launch an
>> RTEMS program I have to recompile the program ( the part after ./bootstrap
>> in the workflow ) ?
> No, you only have to do that if you want to update the toolchain.
> I Tought , the bsps we generate can be used like in this video i found ( it
>> is for µC/OS II on Zynq ) : https://www.youtube.com/watch?v=omB7qVBQaIM
> I'm sorry, if I caused any confusion.
> Cheers,
>    Jan
> Please can anybody else confirm that or give us a clarification.
>> Thank you
>> ________
>> *Badr EL HIOUEL*
>> 2016-03-22 11:16 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>> Am 2016-03-22 09:45, schrieb Badr El Hiouel:
>>> Hi Jan ,
>>>> Thank you for support.
>>>> It finally success! For that , I had to delete all the project, then I
>>>> rebuild RSB and then it went very fine.
>>>> Now , I designed a Zynq HW on Vivado and I launched it on SDK. But now ,
>>>> in
>>>> the labs ( you sent me one for the µZed , The same exists for Zedboard )
>>>> they create a new bsp. I imagine that in this step I don't have to
>>>> create
>>>> one but import it from the rtems.
>>>> This part is a bit tricky. The term "bsp" is used in 2 different
>>>> contexts
>>> here.
>>> First you have the rtems-bsp. That complements the generic parts of rtems
>>> with the things that depend on your intended target platform (i.e.
>>> Zedboard) like drivers for the global timer, etc. This generates the
>>> rtems-library for your platform which is linked to your application code
>>> to
>>> create your RTEMS-application (e.g. ticker.exe).
>>> Then you have the bsp in the Xilinx context. The Zync CPU consists of an
>>> ARM-CPU and an FPGA. In order to run any application on the CPU you also
>>> have to configure the FPGA, which you do with the bsp and the FSBL from
>>> the
>>> Xilinx-toolchain.
>>> I don't know too much about that configuration so far. I simply followed
>>> the tutorial where the FPGA is mainly responsible to connect the CPU to
>>> the
>>> RAM.
>>> In part 4 of the Tutorial for the MicroZed they build a boot image. If
>>> you
>>> take a look at Figure 6 (p. 7), I simply replaced the Periph_Test.elf
>>> with
>>> the test program generated by RTEMS and continued. The setup for the
>>> normal
>>> Zedboard should be pretty similar. The resulting boot image will boot,
>>> initialize the FPGA, load the RTEMS program into RAM and transfer control
>>> to it.
>>> So, where I find the bsp ? It's a single file or a directory ? And then
>>> how
>>>> can I to import it on SDK ?
>>>> I read also that for ticker.exe we have to change the extension for
>>>> .elfe
>>>> is that what I'll have to do ?
>>>> It might be that the file dialog of the Xilinx tools expects
>>>> *.elf-files,
>>> so renaming might be necessary.
>>> Best regards,
>>>    Jan
>>> PS: Please keep the rtems-users list as recipient, so other people might
>>> join the discussion and people with the same problem might benefit.
>>> Thank you!
>>>> ________
>>>> *Badr EL HIOUEL*
>>>> 2016-03-19 11:57 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>>>> Am Friday 18 March 2016, 17:24:48 schrieb Badr El Hiouel:
>>>>> > > Thank you for your support,
>>>>> > > I installed the devel environnement for Python27 and it builds (
>>>>> finally !
>>>>> > > When I did :
>>>>> > > /mnt/D/development/rtems/kernel/rtems/configure
>>>>> --target=arm-rtems4.12
>>>>> > > --enable-rtemsbsp=xilinx_zynq_zedboard --enable-tests=samples
>>>>> > > --enable-posix --enable-cxx
>>>>> --prefix=/mnt/D/development/rtems/bsps/4.12
>>>>> > > BSP_ARM_A9MPCORE_PERIPHCLK=333333333U
>>>>> > > It worked but when running make && make install it shows me an
>>>>> error
>>>>> > > checking for RTEMS_CPU_MODEL...
>>>>> > > checking for RTEMS_BSP_FAMILY... xilinx-zynq
>>>>> > > checking for CPU_CFLAGS... (cached) -march=armv7-a -mthumb
>>>>> -mfpu=neon
>>>>> > > -mfloat-abi=hard -mtune=cortex-a9
>>>>> > > checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>>>>> -ffunction-sections
>>>>> > > -fdata-sections
>>>>> > > checking for style of include used by gmake... GNU
>>>>> > > checking for arm-rtems4.12-gcc... no
>>>>> > > configure: error: no acceptable cc found in $PATH
>>>>> > > gmake[2]: *** [xilinx_zynq_zedboard] Error 1
>>>>> > > gmake[2]: Leaving directory
>>>>> > > `/mnt/D/development/rtems/kernel/zynq/arm-rtems4.12/c'
>>>>> > > gmake[1]: *** [all-recursive] Error 1
>>>>> > > gmake[1]: Leaving directory
>>>>> > > make: *** [all-recursive] Error 1
>>>>> So if I understand it correctly, the RSB finished sucessfully? Then you
>>>>> should have binaries like arm-rtems-4.12-* installed to the directory
>>>>> you
>>>>> passed to the RSB.
>>>>> Configure complains that it cannot find said binaries. That is probably
>>>>> because you haven't added them to your PATH environment variable.
>>>>> You can do that with (use the correct path to the bin-directory of your
>>>>> setup)
>>>>> export PATH=/mnt/D/development/rtems/compiler/4.12/bin:$PATH
>>>>> Try the configure command again after that.
>>>>> > > It's a problem of directories ? or the configuration I did ? ( I
>>>>> took
>>>>> the
>>>>> > > same configuration you did Jan , because I have no ideas what is
>>>>> those
>>>>> > > configurations and how to choose that if any body has an
>>>>> explanation
>>>>> for
>>>>> > > this part)
>>>>> The configure command is part of the autotools and very common in the
>>>>> Linux/Unix world when building programs from source.
>>>>> It checks if all the dependencies are met before you build it and gives
>>>>> you the ability to configure which features of the program you want to
>>>>> enable and where to install it.
>>>>> > > Thank you
>>>>> > > ________
>>>>> > > *Badr EL HIOUEL*
>>>>> > > 2016-03-17 23:16 GMT+01:00 Chris Johns <chrisj at rtems.org>:
>>>>> > >> On 18/03/2016 03:12, Jan Sommer wrote:
>>>>> > >>> Am 2016-03-17 16:31, schrieb Badr El Hiouel:
>>>>> > >>>> I had this error that I can't found anywhere the solution for
>>>>> it.
>>>>> I
>>>>> > >>>> attached the report bug .. Can you please tell me what is going
>>>>> wrong ?
>>>>> > >>> It seems to be the same error which occurs quite often here
>>>>> recently.
>>>>> > >>> Apparently you need to install the python-development packet.
>>>>> > >>> On a debian based distro it should be python-dev or
>>>>> libpython2.7-dev
>>>>> > >> I have added a note about this in the up coming Getting Started
>>>>> Guide:
>>>>> https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html#development-version
>>>>> > >> It is difficult for the RSB to track dependences for packages like
>>>>> this.
>>>>> > >> There are plans but they have not been implemented.
>>>>> > >> Chris
>>>>> > >> _______________________________________________
>>>>> > >> users mailing list
>>>>> > >> users at rtems.org
>>>>> > >> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160322/5bcb472b/attachment-0002.html>
