Workflow RTEMS on Zynq Zedboard
Badr El Hiouel
elh.badr at gmail.com
Tue Mar 22 16:31:15 UTC 2016
Can you please give the link of this tutorial because I think I'm doing
something wrong .. When running the ticker.exe ( which I renamed to .elf )
=> the sdk crashes ..
________
*Badr EL HIOUEL*
Mail : elh.badr at gmail.com
2016-03-22 12:57 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
> Am 2016-03-22 12:33, schrieb Badr El Hiouel:
>> Ok, Thank you.
>> I'm understanding now.
>> I can't find details for the importing part of the ticker.exe program. (
>> in
>> the labs they create a new application project - in other labs they copy
>> an
>> file.c )
>> How did you import the ticker.exe ?
> As I said, if you follow part 4 of the MicroZed tutorial (I don't have the
> one for the Zedboard) and take a look at Figure 6 (p. 7) I replaced the
> file Periph_Test.elf with the elf-file from the ticker-example. I don't use
> the Xilinx SDK to develop the RTEMS application itself.
>> ________
>> *Badr EL HIOUEL*
>> 2016-03-22 12:06 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>> Am 2016-03-22 11:32, schrieb Badr El Hiouel:
>>> I'm a little bit confusing.
>>>> So, if I understand, The 1st part of the workflow ( ie building the RSB
>>>> generating the rtems bsp ) is only for compiling programs ( with as a
>>>> target arm architectures ).
>>>> It generates the toolchain for compiling programs, i.e. compiler,
>>> linker,
>>> RTEMS libraries.
>>> You then write your application code, with tasks, I/O and compile it with
>>> this toolchain.
>>> For example ticker is such an application. It will be compiled and linked
>>> with arm-rtems4.xx-gcc and the result will be your binary ticker.exe,
>>> which
>>> you then have to load to your target platform.
>>> For simpler boards like the raspberry pi you only have to copy the binary
>>> file to the sd-card. For the Zedboard you also have to include a setup
>>> for
>>> the FPGA.
>>> This means , every time I have to launch an
>>>> RTEMS program I have to recompile the program ( the part after
>>>> ./bootstrap
>>>> in the workflow ) ?
>>>> No, you only have to do that if you want to update the toolchain.
>>> I Tought , the bsps we generate can be used like in this video i found (
>>> it
>>>> is for µC/OS II on Zynq ) : https://www.youtube.com/watch?v=omB7qVBQaIM
>>>> I'm sorry, if I caused any confusion.
>>> Cheers,
>>> Jan
>>> Please can anybody else confirm that or give us a clarification.
>>>> Thank you
>>>> ________
>>>> *Badr EL HIOUEL*
>>>> 2016-03-22 11:16 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>>>> Am 2016-03-22 09:45, schrieb Badr El Hiouel:
>>>>> Hi Jan ,
>>>>>> Thank you for support.
>>>>>> It finally success! For that , I had to delete all the project, then I
>>>>>> rebuild RSB and then it went very fine.
>>>>>> Now , I designed a Zynq HW on Vivado and I launched it on SDK. But
>>>>>> now ,
>>>>>> in
>>>>>> the labs ( you sent me one for the µZed , The same exists for
>>>>>> Zedboard )
>>>>>> they create a new bsp. I imagine that in this step I don't have to
>>>>>> create
>>>>>> one but import it from the rtems.
>>>>>> This part is a bit tricky. The term "bsp" is used in 2 different
>>>>>> contexts
>>>>>> here.
>>>>> First you have the rtems-bsp. That complements the generic parts of
>>>>> rtems
>>>>> with the things that depend on your intended target platform (i.e.
>>>>> Zedboard) like drivers for the global timer, etc. This generates the
>>>>> rtems-library for your platform which is linked to your application
>>>>> code
>>>>> to
>>>>> create your RTEMS-application (e.g. ticker.exe).
>>>>> Then you have the bsp in the Xilinx context. The Zync CPU consists of
>>>>> an
>>>>> ARM-CPU and an FPGA. In order to run any application on the CPU you
>>>>> also
>>>>> have to configure the FPGA, which you do with the bsp and the FSBL from
>>>>> the
>>>>> Xilinx-toolchain.
>>>>> I don't know too much about that configuration so far. I simply
>>>>> followed
>>>>> the tutorial where the FPGA is mainly responsible to connect the CPU to
>>>>> the
>>>>> RAM.
>>>>> In part 4 of the Tutorial for the MicroZed they build a boot image. If
>>>>> you
>>>>> take a look at Figure 6 (p. 7), I simply replaced the Periph_Test.elf
>>>>> with
>>>>> the test program generated by RTEMS and continued. The setup for the
>>>>> normal
>>>>> Zedboard should be pretty similar. The resulting boot image will boot,
>>>>> initialize the FPGA, load the RTEMS program into RAM and transfer
>>>>> control
>>>>> to it.
>>>>> So, where I find the bsp ? It's a single file or a directory ? And then
>>>>> how
>>>>> can I to import it on SDK ?
>>>>>> I read also that for ticker.exe we have to change the extension for
>>>>>> .elfe
>>>>>> is that what I'll have to do ?
>>>>>> It might be that the file dialog of the Xilinx tools expects
>>>>>> *.elf-files,
>>>>>> so renaming might be necessary.
>>>>> Best regards,
>>>>> Jan
>>>>> PS: Please keep the rtems-users list as recipient, so other people
>>>>> might
>>>>> join the discussion and people with the same problem might benefit.
>>>>> Thank you!
>>>>>> ________
>>>>>> *Badr EL HIOUEL*
>>>>>> 2016-03-19 11:57 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de
>>>>>> Am Friday 18 March 2016, 17:24:48 schrieb Badr El Hiouel:
>>>>>>> > > Thank you for your support,
>>>>>>> > > I installed the devel environnement for Python27 and it builds (
>>>>>>> finally !
>>>>>>> > > When I did :
>>>>>>> > > /mnt/D/development/rtems/kernel/rtems/configure
>>>>>>> --target=arm-rtems4.12
>>>>>>> > > --enable-rtemsbsp=xilinx_zynq_zedboard --enable-tests=samples
>>>>>>> > > --enable-posix --enable-cxx
>>>>>>> --prefix=/mnt/D/development/rtems/bsps/4.12
>>>>>>> > > BSP_ARM_A9MPCORE_PERIPHCLK=333333333U
>>>>>>> > > It worked but when running make && make install it shows me an
>>>>>>> error
>>>>>>> > > checking for RTEMS_CPU_MODEL...
>>>>>>> > > checking for RTEMS_BSP_FAMILY... xilinx-zynq
>>>>>>> > > checking for CPU_CFLAGS... (cached) -march=armv7-a -mthumb
>>>>>>> -mfpu=neon
>>>>>>> > > -mfloat-abi=hard -mtune=cortex-a9
>>>>>>> > > checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>>>>>>> -ffunction-sections
>>>>>>> > > -fdata-sections
>>>>>>> > > checking for style of include used by gmake... GNU
>>>>>>> > > checking for arm-rtems4.12-gcc... no
>>>>>>> > > configure: error: no acceptable cc found in $PATH
>>>>>>> > > gmake[2]: *** [xilinx_zynq_zedboard] Error 1
>>>>>>> > > gmake[2]: Leaving directory
>>>>>>> > > `/mnt/D/development/rtems/kernel/zynq/arm-rtems4.12/c'
>>>>>>> > > gmake[1]: *** [all-recursive] Error 1
>>>>>>> > > gmake[1]: Leaving directory
>>>>>>> > > make: *** [all-recursive] Error 1
>>>>>>> So if I understand it correctly, the RSB finished sucessfully? Then
>>>>>>> you
>>>>>>> should have binaries like arm-rtems-4.12-* installed to the directory
>>>>>>> you
>>>>>>> passed to the RSB.
>>>>>>> Configure complains that it cannot find said binaries. That is
>>>>>>> probably
>>>>>>> because you haven't added them to your PATH environment variable.
>>>>>>> You can do that with (use the correct path to the bin-directory of
>>>>>>> your
>>>>>>> setup)
>>>>>>> export PATH=/mnt/D/development/rtems/compiler/4.12/bin:$PATH
>>>>>>> Try the configure command again after that.
>>>>>>> > > It's a problem of directories ? or the configuration I did ? ( I
>>>>>>> took
>>>>>>> the
>>>>>>> > > same configuration you did Jan , because I have no ideas what is
>>>>>>> those
>>>>>>> > > configurations and how to choose that if any body has an
>>>>>>> explanation
>>>>>>> for
>>>>>>> > > this part)
>>>>>>> The configure command is part of the autotools and very common in the
>>>>>>> Linux/Unix world when building programs from source.
>>>>>>> It checks if all the dependencies are met before you build it and
>>>>>>> gives
>>>>>>> you the ability to configure which features of the program you want
>>>>>>> to
>>>>>>> enable and where to install it.
>>>>>>> > > Thank you
>>>>>>> > > ________
>>>>>>> > > *Badr EL HIOUEL*
>>>>>>> > > 2016-03-17 23:16 GMT+01:00 Chris Johns <chrisj at rtems.org>:
>>>>>>> > >> On 18/03/2016 03:12, Jan Sommer wrote:
>>>>>>> > >>> Am 2016-03-17 16:31, schrieb Badr El Hiouel:
>>>>>>> > >>>> I had this error that I can't found anywhere the solution for
>>>>>>> it.
>>>>>>> I
>>>>>>> > >>>> attached the report bug .. Can you please tell me what is
>>>>>>> going
>>>>>>> wrong ?
>>>>>>> > >>> It seems to be the same error which occurs quite often here
>>>>>>> recently.
>>>>>>> > >>> Apparently you need to install the python-development packet.
>>>>>>> > >>> On a debian based distro it should be python-dev or
>>>>>>> libpython2.7-dev
>>>>>>> > >> I have added a note about this in the up coming Getting Started
>>>>>>> Guide:
>>>>>>> https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html#development-version
>>>>>>> > >> It is difficult for the RSB to track dependences for packages
>>>>>>> like
>>>>>>> this.
>>>>>>> > >> There are plans but they have not been implemented.
>>>>>>> > >> Chris
>>>>>>> > >> _______________________________________________
>>>>>>> > >> users mailing list
>>>>>>> > >> users at rtems.org
>>>>>>> > >> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160322/f7080dd9/attachment-0002.html>
