rsb for arm
Joel Sherrill
joel at rtems.org
Thu Mar 24 14:07:20 UTC 2016
Is it being built with -Werror?
FWIW I don't see gcc 5.2.1 as an official release. I see 5.2 and 5.3. Is
that
other digit from the distribution?
--joel
On Thu, Mar 24, 2016 at 8:45 AM, D Peter Siddons <siddons at bnl.gov> wrote:
> Hi Matt,
> I'm running gcc 5.2.1.
> Pete.
> On 03/24/2016 09:36 AM, Matthew Clark wrote:
>> I ran into this problem myself. Basically, the macro that determines
>> the GCC version isn't working correctly, so it's defining those
>> functions twice. Are you running GCC 5.x? I had to comment out the
>> code for if the GCC version < 3.0. It's kind of a pain because it
>> means you'll bludgeon the build process as re-running the
>> source-builder process will just blow out the old build folder,
>> extract the code fresh and you'll have the same problem.
>> Matt
>> On Thu, Mar 17, 2016 at 9:55 AM, D Peter Siddons <siddons at bnl.gov> wrote:
>>> Hi Chris,
>>> I searched l-arm.txt for ": error" and found the lines in the attached
>>> file.
>>> Hope that helps.
>>> I remember seeing something some time ago with Ubuntu. They link
>>> /bin/sh
>>> to /bin/dash instead of /bin/bash. I'm nervous about changing that in
>>> case
>>> the system relies on dash-like behaviour, but I do remember that giving
>>> mysterious problems once.
>>> Pete.
>>> On 03/16/2016 10:14 PM, Chris Johns wrote:
>>>> On 17/03/2016 12:42, D Peter Siddons wrote:
>>>>> Recently upgraded from 15.04 to 15.10.
>>>> Ok.
>>>> Report attached.
>>>> Hmm the error was before the report log. I never expected these level of
>>>> warnings but building old compilers with newer ones can do this.
>>>> I will try and recreate the build.
>>>> Any chance you could peak in the log file and cut and paste the error?
>>>> Thanks
>>>> Chris
>>> D. Peter Siddons
>>> Detector Development Group Leader
>>> Bldg. 535B
>>> Photon Sciences Directorate,
>>> Brookhaven National Laboratory
>>> Upton, NY 11973
>>> email: siddons at bnl.gov
>>> Phone: (631) 344-2738
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> D. Peter Siddons
> Bldg. 535B
> Upton, NY 11973
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160324/74665be7/attachment-0002.html>
