No RTEMS 4.11 in RSB?
Gerald Needell jerry.needell at unh.edu
Tue May 10 16:00:02 UTC 2016
Jan
After making the suggested change (or just specifying 4.10 in
rtems-base.bset) the tool build fine, but the kernel build fails trying
to download the source as indicated below.
I'm not having much luck following the scripts to find the problem.
Is the problem obvious to you?
Thanks
Jerry
config: tools/rtems-kernel-4.10.2.cfg
package: sparc-rtems4.10-kernel-4.12 (8bcc58b249fb)-1
download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12 ->
sources/rtems-4.12 (8bcc58b249fb).tar.bz2
download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12: error:
<urlopen error ftp error: [Errno ftp error] 550 Failed to change
directory.>
error: downloading (8bcc58b249fb).tar.bz2: all paths have failed, giving
up
Build FAILED
  See error report: rsb-report-sparc-rtems4.10-kernel-4.12
(8bcc58b249fb)-1.txt
up
Build Set: Time 0:06:37.374873
Build FAILED
On Tue, 2016-05-10 at 10:59 -0400, Needell, Jerry wrote:
> Jan - thanks - that fix allows me to build the 4.10 toolset OK but now
> if crashes when building the items kernel - I’ll look for similar
> issues there - progress …
> Jerry
> > On May 10, 2016, at 10:30 AM, Jan Sommer
> > <soja-lists at aries.uberspace.de> wrote:
> > Am 2016-05-10 15:59, schrieb Gerald Needell:
> > > additionally, if I try to build the 4.10 bset it fails to build
> > > binutils
> > > and it there appears to be some misconfiguration with the 4.12
> > > toolset ...
> > > Any suggestions?
> > There seems to be some problems with the versioning. You can try to
> > comment/delete the line
> > %include rtems-version.bset
> > from rtems/config/rtems-base.bset
> > It looks like it overwrites the global rtems-version variable with
> > 4.12 even if it was set to 4.10 previously.
> > Cheers,
> >   Jan
> > > Thanks
> > > Jerry
> > > [rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder
> > > --log=l-sparc-4.10.txt --prefix=
> > > $HOME/sandbox/development/rtems/4.10
> > > 4.10/rtems-sparc
> > > RTEMS Source Builder - Set Builder, 4.12 (8bcc58b249fb)
> > > Build Set: 4.10/rtems-sparc
> > > config: devel/expat-2.1.0-1.cfg
> > > package: expat-2.1.0-x86_64-linux-gnu-1
> > > Creating source directory: sources
> > > download:
> > > https://urldefense.proofpoint.com/v2/url?u=http-3A__downloads.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=tJcqQjQm5LGoqmLHoTXvBre5tRt1F4rSzkiWUsuAg3g&e= -> sources/expat-2.1.0.tar.gz
> > > redirect:
> > > https://urldefense.proofpoint.com/v2/url?u=http-3A__liquidtelecom.dl.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=QOqlnYqJeW1jnG8KkqwpVm-mdJuM3DzHuRGe9kVp2Qk&e= downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
> > > building: expat-2.1.0-x86_64-linux-gnu-1
> > > reporting: devel/expat-2.1.0-1.cfg ->
> > > expat-2.1.0-x86_64-linux-gnu-1.txt
> > > expat-2.1.0-x86_64-linux-gnu-1.xml
> > > config: tools/rtems-binutils-2.20.1-1.cfg
> > > package: sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1
> > > download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.gnu.org_gnu_binutils_binutils-2D2.20.1.tar.bz2&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=viGpJ6834sjYum0y35mRwTSPkhi3UXpbPInEiZLbhlM&e=  ->
> > > sources/binutils-2.20.1.tar.bz2
> > > downloading: sources/binutils-2.20.1.tar.bz2 - 16.8MB of 16.8MB
> > > (100%)
> > > Creating source directory: patches
> > > download:
> > > https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=OGE4uI9NT55EyRCXcoxNwBQOVz7ucQAdroTKAzYStDk&e= -> patches/binutils-2.20.1-rtems4.10-20100826.diff
> > > download:
> > > https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= error: HTTP Error 404: Not found
> > > error: downloading
> > > https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= all paths have failed, giving up
> > > Build FAILED
> > >  See error report:
> > > rsb-report-sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1.txt
> > > error: downloading
> > > Build Set: Time 0:00:12.468130
> > > Build FAILED
> > > On Tue, 2016-05-10 at 13:39 +0000, Gerald Needell wrote:
> > > > When I check for the available bsets I don't see any 4.11 bset.
> > > > Where did it go?
> > > > Thanks
> > > > Jerry
> > > > --list-bsets
> > > > Examining: config
> > > > Examining: ../source-builder/config
> > > > Examining: ../bare/config
> > > >    4.10/rtems-all.bset
> > > >    4.10/rtems-arm.bset
> > > >    4.10/rtems-autotools.bset
> > > >    4.10/rtems-avr.bset
> > > >    4.10/rtems-bfin.bset
> > > >    4.10/rtems-h8300.bset
> > > >    4.10/rtems-i386.bset
> > > >    4.10/rtems-lm32.bset
> > > >    4.10/rtems-m32c.bset
> > > >    4.10/rtems-m32r.bset
> > > >    4.10/rtems-m68k.bset
> > > >    4.10/rtems-mips.bset
> > > >    4.10/rtems-nios2.bset
> > > >    4.10/rtems-powerpc.bset
> > > >    4.10/rtems-sh.bset
> > > >    4.10/rtems-sparc.bset
> > > >    4.12/rtems-aarch64.bset
> > > >    4.12/rtems-all.bset
> > > >    4.12/rtems-arm.bset
> > > >    4.12/rtems-autotools-base.bset
> > > >    4.12/rtems-autotools-internal.bset
> > > >    4.12/rtems-autotools.bset
> > > >    4.12/rtems-bfin.bset
> > > >    4.12/rtems-default.bset
> > > >    4.12/rtems-epiphany.bset
> > > >    4.12/rtems-i386.bset
> > > >    4.12/rtems-lm32.bset
> > > >    4.12/rtems-m32c.bset
> > > >    4.12/rtems-m68k.bset
> > > >    4.12/rtems-microblaze.bset
> > > >    4.12/rtems-mips.bset
> > > >    4.12/rtems-moxie.bset
> > > >    4.12/rtems-nios2.bset
> > > >    4.12/rtems-or1k.bset
> > > >    4.12/rtems-powerpc.bset
> > > >    4.12/rtems-sh.bset
> > > >    4.12/rtems-sparc.bset
> > > >    4.12/rtems-sparc64.bset
> > > >    4.12/rtems-tools.bset
> > > >    4.12/rtems-v850.bset
> > > >    4.12/rtems-x86_64.bset
> > > >    4.9/rtems-all.bset
> > > >    4.9/rtems-arm.bset
> > > >    4.9/rtems-autotools.bset
> > > >    4.9/rtems-i386.bset
> > > >    4.9/rtems-m68k.bset
> > > >    4.9/rtems-mips.bset
> > > >    4.9/rtems-powerpc.bset
> > > >    4.9/rtems-sparc.bset
> > > >    databases/sqlite.bset
> > > >    devel/autotools-base.bset
> > > >    devel/autotools-internal.bset
> > > >    devel/autotools.bset
> > > >    devel/dtc.bset
> > > >    devel/libtool.bset
> > > >    devel/libusb.bset
> > > >    devel/or1ksim.bset
> > > >    devel/qemu.bset
> > > >    gnu-tools-4.6.bset
> > > >    gnu-tools-4.8.2.bset
> > > >    graphics/freetype2.bset
> > > >    graphics/graphics-all.bset
> > > >    graphics/libjpeg.bset
> > > >    graphics/libpng.bset
> > > >    graphics/libtiff.bset
> > > >    graphics/microwindows.bset
> > > >    graphics/nxlib.bset
> > > >    graphics/t1lib.bset
> > > >    lang/gcc491.bset
> > > >    net-mgmt/net-snmp.bset
> > > >    net/lwip.bset
> > > >    net/ntp.bset
> > > >    net/protobuf.bset
> > > >    rtems-4.10-base.bset
> > > >    rtems-4.9-base.bset
> > > >    rtems-base.bset
> > > >    rtems-package.bset
> > > >    rtems-urls.bset
> > > >    rtems-version.bset
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=pEEEjIK6rr5PNYSUPKmMmB57RLit3ky08iFXiBMVTyU&e=
