No RTEMS 4.11 in RSB?
Jan Sommer soja-lists at aries.uberspace.de
Tue May 10 22:25:01 UTC 2016
Am Dienstag, 10. Mai 2016, 16:07:05 CEST schrieb Gerald Needell:
> Jan
> Sorry - Our mail-scanner makes a mess of the URLS in the mail message:
> It looks like it is trying to download from :
> "rtems/releases/4.10/4.12"
Hm. I have never used the rsb to build rtems itself. I always simply downloaded/checked out the sources and then ran configure and make.
You can try that. The rsb-scripts will do the same anyways.
Best regards,
   Jan
> Jerry
> On Tue, 2016-05-10 at 16:00 +0000, Gerald Needell wrote:
> > Jan
> > After making the suggested change (or just specifying 4.10 in
> > rtems-base.bset) the tool build fine, but the kernel build fails trying
> > to download the source as indicated below.
> > I'm not having much luck following the scripts to find the problem.
> > Is the problem obvious to you?
> > Thanks
> > Jerry
> > config: tools/rtems-kernel-4.10.2.cfg
> > package: sparc-rtems4.10-kernel-4.12 (8bcc58b249fb)-1
> > download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.10_4.12&d=CwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=MPR6v2v_7ER94yys3ACwImnCphpf4m8lhGkDejwp4Jc&s=0qxgK0jstMDvzftDvg6yt-P4Yc2nASriPGbXUHUXaQQ&e=  ->
> > sources/rtems-4.12 (8bcc58b249fb).tar.bz2
> > download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.10_4.12-3A&d=CwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=MPR6v2v_7ER94yys3ACwImnCphpf4m8lhGkDejwp4Jc&s=v2Gqp9mxkCYLw9-1DsFAp5lX-4NpUfjaSxWL1CW0AE8&e=  error:
> > <urlopen error ftp error: [Errno ftp error] 550 Failed to change
> > directory.>
> > error: downloading (8bcc58b249fb).tar.bz2: all paths have failed, giving
> > up
> > Build FAILED
> >   See error report: rsb-report-sparc-rtems4.10-kernel-4.12
> > (8bcc58b249fb)-1.txt
> > up
> > Build Set: Time 0:06:37.374873
> > Build FAILED
> > On Tue, 2016-05-10 at 10:59 -0400, Needell, Jerry wrote:
> > > Jan - thanks - that fix allows me to build the 4.10 toolset OK but now
> > > if crashes when building the items kernel - I’ll look for similar
> > > issues there - progress …
> > > Jerry
> > > > On May 10, 2016, at 10:30 AM, Jan Sommer
> > > > <soja-lists at aries.uberspace.de> wrote:
> > > > Am 2016-05-10 15:59, schrieb Gerald Needell:
> > > > > additionally, if I try to build the 4.10 bset it fails to build
> > > > > binutils
> > > > > and it there appears to be some misconfiguration with the 4.12
> > > > > toolset ...
> > > > > Any suggestions?
> > > > There seems to be some problems with the versioning. You can try to
> > > > comment/delete the line
> > > > %include rtems-version.bset
> > > > from rtems/config/rtems-base.bset
> > > > It looks like it overwrites the global rtems-version variable with
> > > > 4.12 even if it was set to 4.10 previously.
> > > > Cheers,
> > > >   Jan
> > > > > Thanks
> > > > > Jerry
> > > > > [rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder
> > > > > --log=l-sparc-4.10.txt --prefix=
> > > > > $HOME/sandbox/development/rtems/4.10
> > > > > 4.10/rtems-sparc
> > > > > RTEMS Source Builder - Set Builder, 4.12 (8bcc58b249fb)
> > > > > Build Set: 4.10/rtems-sparc
> > > > > config: devel/expat-2.1.0-1.cfg
> > > > > package: expat-2.1.0-x86_64-linux-gnu-1
> > > > > Creating source directory: sources
> > > > > download:
> > > > > https://urldefense.proofpoint.com/v2/url?u=http-3A__downloads.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=tJcqQjQm5LGoqmLHoTXvBre5tRt1F4rSzkiWUsuAg3g&e= -> sources/expat-2.1.0.tar.gz
> > > > > redirect:
> > > > > https://urldefense.proofpoint.com/v2/url?u=http-3A__liquidtelecom.dl.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=QOqlnYqJeW1jnG8KkqwpVm-mdJuM3DzHuRGe9kVp2Qk&e= downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
> > > > > building: expat-2.1.0-x86_64-linux-gnu-1
> > > > > reporting: devel/expat-2.1.0-1.cfg ->
> > > > > expat-2.1.0-x86_64-linux-gnu-1.txt
> > > > > expat-2.1.0-x86_64-linux-gnu-1.xml
> > > > > config: tools/rtems-binutils-2.20.1-1.cfg
> > > > > package: sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1
> > > > > download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.gnu.org_gnu_binutils_binutils-2D2.20.1.tar.bz2&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=viGpJ6834sjYum0y35mRwTSPkhi3UXpbPInEiZLbhlM&e=  ->
> > > > > sources/binutils-2.20.1.tar.bz2
> > > > > downloading: sources/binutils-2.20.1.tar.bz2 - 16.8MB of 16.8MB
> > > > > (100%)
> > > > > Creating source directory: patches
> > > > > download:
> > > > > https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=OGE4uI9NT55EyRCXcoxNwBQOVz7ucQAdroTKAzYStDk&e= -> patches/binutils-2.20.1-rtems4.10-20100826.diff
> > > > > download:
> > > > > https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= error: HTTP Error 404: Not found
> > > > > error: downloading
> > > > > https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= all paths have failed, giving up
> > > > > Build FAILED
> > > > >  See error report:
> > > > > rsb-report-sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1.txt
> > > > > error: downloading
> > > > > Build Set: Time 0:00:12.468130
> > > > > Build FAILED
> > > > > On Tue, 2016-05-10 at 13:39 +0000, Gerald Needell wrote:
> > > > > > When I check for the available bsets I don't see any 4.11 bset.
> > > > > > Where did it go?
> > > > > > Thanks
> > > > > > Jerry
> > > > > > --list-bsets
> > > > > > Examining: config
> > > > > > Examining: ../source-builder/config
> > > > > > Examining: ../bare/config
> > > > > >    4.10/rtems-all.bset
> > > > > >    4.10/rtems-arm.bset
> > > > > >    4.10/rtems-autotools.bset
> > > > > >    4.10/rtems-avr.bset
> > > > > >    4.10/rtems-bfin.bset
> > > > > >    4.10/rtems-h8300.bset
> > > > > >    4.10/rtems-i386.bset
> > > > > >    4.10/rtems-lm32.bset
> > > > > >    4.10/rtems-m32c.bset
> > > > > >    4.10/rtems-m32r.bset
> > > > > >    4.10/rtems-m68k.bset
> > > > > >    4.10/rtems-mips.bset
> > > > > >    4.10/rtems-nios2.bset
> > > > > >    4.10/rtems-powerpc.bset
> > > > > >    4.10/rtems-sh.bset
> > > > > >    4.10/rtems-sparc.bset
> > > > > >    4.12/rtems-aarch64.bset
> > > > > >    4.12/rtems-all.bset
> > > > > >    4.12/rtems-arm.bset
> > > > > >    4.12/rtems-autotools-base.bset
> > > > > >    4.12/rtems-autotools-internal.bset
> > > > > >    4.12/rtems-autotools.bset
> > > > > >    4.12/rtems-bfin.bset
> > > > > >    4.12/rtems-default.bset
> > > > > >    4.12/rtems-epiphany.bset
> > > > > >    4.12/rtems-i386.bset
> > > > > >    4.12/rtems-lm32.bset
> > > > > >    4.12/rtems-m32c.bset
> > > > > >    4.12/rtems-m68k.bset
> > > > > >    4.12/rtems-microblaze.bset
> > > > > >    4.12/rtems-mips.bset
> > > > > >    4.12/rtems-moxie.bset
> > > > > >    4.12/rtems-nios2.bset
> > > > > >    4.12/rtems-or1k.bset
> > > > > >    4.12/rtems-powerpc.bset
> > > > > >    4.12/rtems-sh.bset
> > > > > >    4.12/rtems-sparc.bset
> > > > > >    4.12/rtems-sparc64.bset
> > > > > >    4.12/rtems-tools.bset
> > > > > >    4.12/rtems-v850.bset
> > > > > >    4.12/rtems-x86_64.bset
> > > > > >    4.9/rtems-all.bset
> > > > > >    4.9/rtems-arm.bset
> > > > > >    4.9/rtems-autotools.bset
> > > > > >    4.9/rtems-i386.bset
> > > > > >    4.9/rtems-m68k.bset
> > > > > >    4.9/rtems-mips.bset
> > > > > >    4.9/rtems-powerpc.bset
> > > > > >    4.9/rtems-sparc.bset
> > > > > >    databases/sqlite.bset
> > > > > >    devel/autotools-base.bset
> > > > > >    devel/autotools-internal.bset
> > > > > >    devel/autotools.bset
> > > > > >    devel/dtc.bset
> > > > > >    devel/libtool.bset
> > > > > >    devel/libusb.bset
> > > > > >    devel/or1ksim.bset
> > > > > >    devel/qemu.bset
> > > > > >    gnu-tools-4.6.bset
> > > > > >    gnu-tools-4.8.2.bset
> > > > > >    graphics/freetype2.bset
> > > > > >    graphics/graphics-all.bset
> > > > > >    graphics/libjpeg.bset
> > > > > >    graphics/libpng.bset
> > > > > >    graphics/libtiff.bset
> > > > > >    graphics/microwindows.bset
> > > > > >    graphics/nxlib.bset
> > > > > >    graphics/t1lib.bset
> > > > > >    lang/gcc491.bset
> > > > > >    net-mgmt/net-snmp.bset
> > > > > >    net/lwip.bset
> > > > > >    net/ntp.bset
> > > > > >    net/protobuf.bset
> > > > > >    rtems-4.10-base.bset
> > > > > >    rtems-4.9-base.bset
> > > > > >    rtems-base.bset
> > > > > >    rtems-package.bset
> > > > > >    rtems-urls.bset
> > > > > >    rtems-version.bset
> > > > > _______________________________________________
> > > > > users mailing list
> > > > > users at rtems.org
> > > > > https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=pEEEjIK6rr5PNYSUPKmMmB57RLit3ky08iFXiBMVTyU&e=
