No RTEMS 4.11 in RSB?
Needell, Jerry Jerry.Needell at unh.edu
Tue May 10 23:19:31 UTC 2016
And unfortunately, when RSB fails building the kernel, it has not fully installed the tools so they can be used …
I’ll keep poking around, but I do think the RSB needs some cleanup for pre 4.12 usage.
By the way, 4.12 worked fine!
Thanks to all for the support.
Jerry
> On May 10, 2016, at 6:54 PM, Needell, Jerry <Jerry.Needell at unh.edu> wrote:
> Jan,
> Thanks. Ultimately I use my own version any way so that's fine. I just wanted to point out the problem.  The RSB is a very nice tool and I want to encourage people to take advantage of it.
> Thanks for the help!
> Best regards,
> Jerry
> Jerry Needell
> jerry.needell at unh.edu
> +1 603 969 6723
>> On May 10, 2016, at 18:25, Jan Sommer <soja-lists at aries.uberspace.de> wrote:
>> Am Dienstag, 10. Mai 2016, 16:07:05 CEST schrieb Gerald Needell:
>>> Jan
>>> Sorry - Our mail-scanner makes a mess of the URLS in the mail message:
>>> It looks like it is trying to download from :
>>> "rtems/releases/4.10/4.12"
>> Hm. I have never used the rsb to build rtems itself. I always simply downloaded/checked out the sources and then ran configure and make.
>> You can try that. The rsb-scripts will do the same anyways.
>> Best regards,
>>  Jan
>>> Jerry
>>>> On Tue, 2016-05-10 at 16:00 +0000, Gerald Needell wrote:
>>>> Jan
>>>> After making the suggested change (or just specifying 4.10 in
>>>> rtems-base.bset) the tool build fine, but the kernel build fails trying
>>>> to download the source as indicated below.
>>>> I'm not having much luck following the scripts to find the problem.
>>>> Is the problem obvious to you?
>>>> Thanks
>>>> Jerry
>>>> config: tools/rtems-kernel-4.10.2.cfg
>>>> package: sparc-rtems4.10-kernel-4.12 (8bcc58b249fb)-1
>>>> download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.10_4.12&d=CwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=MPR6v2v_7ER94yys3ACwImnCphpf4m8lhGkDejwp4Jc&s=0qxgK0jstMDvzftDvg6yt-P4Yc2nASriPGbXUHUXaQQ&e=  ->
>>>> sources/rtems-4.12 (8bcc58b249fb).tar.bz2
>>>> download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.10_4.12-3A&d=CwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=MPR6v2v_7ER94yys3ACwImnCphpf4m8lhGkDejwp4Jc&s=v2Gqp9mxkCYLw9-1DsFAp5lX-4NpUfjaSxWL1CW0AE8&e=  error:
>>>> <urlopen error ftp error: [Errno ftp error] 550 Failed to change
>>>> directory.>
>>>> error: downloading (8bcc58b249fb).tar.bz2: all paths have failed, giving
>>>> up
>>>> Build FAILED
>>>> See error report: rsb-report-sparc-rtems4.10-kernel-4.12
>>>> (8bcc58b249fb)-1.txt
>>>> up
>>>> Build Set: Time 0:06:37.374873
>>>> Build FAILED
>>>>> On Tue, 2016-05-10 at 10:59 -0400, Needell, Jerry wrote:
>>>>> Jan - thanks - that fix allows me to build the 4.10 toolset OK but now
>>>>> if crashes when building the items kernel - I’ll look for similar
>>>>> issues there - progress …
>>>>> Jerry
>>>>>> On May 10, 2016, at 10:30 AM, Jan Sommer
>>>>>> Am 2016-05-10 15:59, schrieb Gerald Needell:
>>>>>>> additionally, if I try to build the 4.10 bset it fails to build
>>>>>>> binutils
>>>>>>> and it there appears to be some misconfiguration with the 4.12
>>>>>>> toolset ...
>>>>>>> Any suggestions?
>>>>>> There seems to be some problems with the versioning. You can try to
>>>>>> comment/delete the line
>>>>>> %include rtems-version.bset
>>>>>> from rtems/config/rtems-base.bset
>>>>>> It looks like it overwrites the global rtems-version variable with
>>>>>> 4.12 even if it was set to 4.10 previously.
>>>>>> Cheers,
>>>>>> Jan
>>>>>>> Thanks
>>>>>>> Jerry
>>>>>>> [rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder
>>>>>>> --log=l-sparc-4.10.txt --prefix=
>>>>>>> $HOME/sandbox/development/rtems/4.10
>>>>>>> 4.10/rtems-sparc
>>>>>>> RTEMS Source Builder - Set Builder, 4.12 (8bcc58b249fb)
>>>>>>> Build Set: 4.10/rtems-sparc
>>>>>>> config: devel/expat-2.1.0-1.cfg
>>>>>>> package: expat-2.1.0-x86_64-linux-gnu-1
>>>>>>> Creating source directory: sources
>>>>>>> download:
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__downloads.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=tJcqQjQm5LGoqmLHoTXvBre5tRt1F4rSzkiWUsuAg3g&e= -> sources/expat-2.1.0.tar.gz
>>>>>>> redirect:
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__liquidtelecom.dl.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=QOqlnYqJeW1jnG8KkqwpVm-mdJuM3DzHuRGe9kVp2Qk&e= downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
>>>>>>> building: expat-2.1.0-x86_64-linux-gnu-1
>>>>>>> reporting: devel/expat-2.1.0-1.cfg ->
>>>>>>> expat-2.1.0-x86_64-linux-gnu-1.txt
>>>>>>> expat-2.1.0-x86_64-linux-gnu-1.xml
>>>>>>> config: tools/rtems-binutils-2.20.1-1.cfg
>>>>>>> package: sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1
>>>>>>> download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.gnu.org_gnu_binutils_binutils-2D2.20.1.tar.bz2&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=viGpJ6834sjYum0y35mRwTSPkhi3UXpbPInEiZLbhlM&e=  ->
>>>>>>> sources/binutils-2.20.1.tar.bz2
>>>>>>> downloading: sources/binutils-2.20.1.tar.bz2 - 16.8MB of 16.8MB
>>>>>>> (100%)
>>>>>>> Creating source directory: patches
>>>>>>> download:
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=OGE4uI9NT55EyRCXcoxNwBQOVz7ucQAdroTKAzYStDk&e= -> patches/binutils-2.20.1-rtems4.10-20100826.diff
>>>>>>> download:
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= error: HTTP Error 404: Not found
>>>>>>> error: downloading
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= all paths have failed, giving up
>>>>>>> Build FAILED
>>>>>>> See error report:
>>>>>>> rsb-report-sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1.txt
>>>>>>> error: downloading
>>>>>>> Build Set: Time 0:00:12.468130
>>>>>>> Build FAILED
>>>>>>>> On Tue, 2016-05-10 at 13:39 +0000, Gerald Needell wrote:
>>>>>>>> When I check for the available bsets I don't see any 4.11 bset.
>>>>>>>> Where did it go?
>>>>>>>> Thanks
>>>>>>>> Jerry
>>>>>>>> --list-bsets
>>>>>>>> Examining: config
>>>>>>>> Examining: ../source-builder/config
>>>>>>>> Examining: ../bare/config
>>>>>>>>  4.10/rtems-all.bset
>>>>>>>>  4.10/rtems-arm.bset
>>>>>>>>  4.10/rtems-autotools.bset
>>>>>>>>  4.10/rtems-avr.bset
>>>>>>>>  4.10/rtems-bfin.bset
>>>>>>>>  4.10/rtems-h8300.bset
>>>>>>>>  4.10/rtems-i386.bset
>>>>>>>>  4.10/rtems-lm32.bset
>>>>>>>>  4.10/rtems-m32c.bset
>>>>>>>>  4.10/rtems-m32r.bset
>>>>>>>>  4.10/rtems-m68k.bset
>>>>>>>>  4.10/rtems-mips.bset
>>>>>>>>  4.10/rtems-nios2.bset
>>>>>>>>  4.10/rtems-powerpc.bset
>>>>>>>>  4.10/rtems-sh.bset
>>>>>>>>  4.10/rtems-sparc.bset
>>>>>>>>  4.12/rtems-aarch64.bset
>>>>>>>>  4.12/rtems-all.bset
>>>>>>>>  4.12/rtems-arm.bset
>>>>>>>>  4.12/rtems-autotools-base.bset
>>>>>>>>  4.12/rtems-autotools-internal.bset
>>>>>>>>  4.12/rtems-autotools.bset
>>>>>>>>  4.12/rtems-bfin.bset
>>>>>>>>  4.12/rtems-default.bset
>>>>>>>>  4.12/rtems-epiphany.bset
>>>>>>>>  4.12/rtems-i386.bset
>>>>>>>>  4.12/rtems-lm32.bset
>>>>>>>>  4.12/rtems-m32c.bset
>>>>>>>>  4.12/rtems-m68k.bset
>>>>>>>>  4.12/rtems-microblaze.bset
>>>>>>>>  4.12/rtems-mips.bset
>>>>>>>>  4.12/rtems-moxie.bset
>>>>>>>>  4.12/rtems-nios2.bset
>>>>>>>>  4.12/rtems-or1k.bset
>>>>>>>>  4.12/rtems-powerpc.bset
>>>>>>>>  4.12/rtems-sh.bset
>>>>>>>>  4.12/rtems-sparc.bset
>>>>>>>>  4.12/rtems-sparc64.bset
>>>>>>>>  4.12/rtems-tools.bset
>>>>>>>>  4.12/rtems-v850.bset
>>>>>>>>  4.12/rtems-x86_64.bset
>>>>>>>>  4.9/rtems-all.bset
>>>>>>>>  4.9/rtems-arm.bset
>>>>>>>>  4.9/rtems-autotools.bset
>>>>>>>>  4.9/rtems-i386.bset
>>>>>>>>  4.9/rtems-m68k.bset
>>>>>>>>  4.9/rtems-mips.bset
>>>>>>>>  4.9/rtems-powerpc.bset
>>>>>>>>  4.9/rtems-sparc.bset
>>>>>>>>  databases/sqlite.bset
>>>>>>>>  devel/autotools-base.bset
>>>>>>>>  devel/autotools-internal.bset
>>>>>>>>  devel/autotools.bset
>>>>>>>>  devel/dtc.bset
>>>>>>>>  devel/libtool.bset
>>>>>>>>  devel/libusb.bset
>>>>>>>>  devel/or1ksim.bset
>>>>>>>>  devel/qemu.bset
>>>>>>>>  gnu-tools-4.6.bset
>>>>>>>>  gnu-tools-4.8.2.bset
>>>>>>>>  graphics/freetype2.bset
>>>>>>>>  graphics/graphics-all.bset
>>>>>>>>  graphics/libjpeg.bset
>>>>>>>>  graphics/libpng.bset
>>>>>>>>  graphics/libtiff.bset
>>>>>>>>  graphics/microwindows.bset
>>>>>>>>  graphics/nxlib.bset
>>>>>>>>  graphics/t1lib.bset
>>>>>>>>  lang/gcc491.bset
>>>>>>>>  net-mgmt/net-snmp.bset
>>>>>>>>  net/lwip.bset
>>>>>>>>  net/ntp.bset
>>>>>>>>  net/protobuf.bset
>>>>>>>>  rtems-4.10-base.bset
>>>>>>>>  rtems-4.9-base.bset
>>>>>>>>  rtems-base.bset
>>>>>>>>  rtems-package.bset
>>>>>>>>  rtems-urls.bset
>>>>>>>>  rtems-version.bset
>>>>>>> _______________________________________________
>>>>>>> users mailing list
>>>>>>> users at rtems.org
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=pEEEjIK6rr5PNYSUPKmMmB57RLit3ky08iFXiBMVTyU&e=
>> users mailing list
>> users at rtems.org
>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=CwIGaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=w-Ylv3FlE904Sun1Jf0ushkZuMYzsJ10LEJk3mKipus&s=QgVJmbxQZxWiILy2YJwwBnGbOGaklPLTXiziXzndBBM&e=
