No RTEMS 4.11 in RSB?
Needell, Jerry Jerry.Needell at unh.edu
Wed May 11 11:14:05 UTC 2016
Chris,
Thanks for all you do to support this.
I’m slowly unraveling how it works and it been educational to work through it.  If I figure out how to fix it, I’ll send you the patches.
Jerry
> On May 10, 2016, at 9:03 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 11/05/2016 09:19, Needell, Jerry wrote:
>> And unfortunately, when RSB fails building the kernel, it has not fully installed the tools so they can be used …
>> I’ll keep poking around, but I do think the RSB needs some cleanup for pre 4.12 usage.
>> By the way, 4.12 worked fine!
>> Thanks to all for the support.
> Fixing this is in the queue. I just need to find the time to do this.
> Chris
