RFS data loss for open files and ways to work around it
Alan Cudmore
alan.cudmore at gmail.com
Wed May 11 14:45:32 UTC 2016
We use RFS on a RAM data recorder on one of our missions ( MMS satellites
). If we know the processor is going to be rebooted ( exception, commanded
reset, etc ) the code closes all open files and calls rtems_bdbuf_syncdev
to flush the buffer cache.
If we get an unexpected reset or watchdog, there is not much we can do.
That is where a journaling system would come in, but I would imagine it has
a performance overhead.
I don't think we have had many resets at all in over a year on orbit. (
maybe one reset in one of the four sats? )
On Tue, May 10, 2016 at 8:01 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 09/05/2016 15:32, Mohammed Saeed Khoory wrote:
>> Hi,
>> I'm using RFS on a RAMDisk for a LEON3-based system. My program tends to
>> keep files open while writing to them periodically. I've noticed that if
>> the system was reset, the files that were open lose all of the data that
>> was written since they were last open. The files still exist in the
>> filesystem, just with a size of 0. Interestingly however, the free space
>> blocks used by those writes are not reclaimed and is gone, and the only way
>> to get it back from what I can tell is to reformat. An fsck-style tool
>> would probably work too but that doesn't exist.
>> The way I work around this is that instead of keeping files open, I open
>> the file, write a little, then close instantly. The changes are then
>> preserved in the filesystem if a reset occurs. However, this method is
>> rather awkward, and I was wondering if there's a better way of doing it.
>> I've tried using fflush() and sync(), but that didn't help. Is there a
>> proper way to "synchronize" the writes to the filesystem?
> I seem to remember duplicating the fd with a dup2 call (I think) and then
> closing the new fd should help. This flushes out the libc parts. The RFS
> does not hold any unwritten data, it is pushed to the cache. You will still
> need to sync the block cache layer. See the 'blksync' command in the shell
> for code on how to do this.
> As Sebastian points out there is a limit to what can be achieved as the
> RFS does not have a journal. How this effects your systems is something you
> will need to determine.
> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160511/3b2f65f4/attachment.html>
