No RTEMS 4.11 in RSB?
Needell, Jerry Jerry.Needell at unh.edu
Fri May 13 11:55:11 UTC 2016
Chris,
That was all it took:
4.10   and 4.9 build fine as long as 2 changes are made:
1)
As Jan suggested:
delete the line
%include rtems-version.bset
from rtems/config/rtems-base.bset
2)
as you suggested:
In config/tools/rtems-kernel-4.10.2.cfg oyu change:
%define rtems_kernel_version     4.10.2
to:
%define rsb_version 4.10.2
Note, the hash rtems_kernel_version also needs to change to rsb_version.
I made the same charge for 4.9 but I did not test it without the change - may not have mattered.
Note: for 4.9 it is also necessary to install texinfo-4.13 as described in the wiki.
But - change #1  now causes 4.12 to fail since items-version is not defined.
I’m trying to find a way to keep them all happy!
What  is the status of returning 4.11 to the RSB bsets list?
Jerry
> On May 11, 2016, at 11:24 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 11/05/2016 21:14, Needell, Jerry wrote:
>> Thanks for all you do to support this.
> No problem.
>> I’m slowly unraveling how it works and it been educational to work through it.  If I figure out how to fix it, I’ll send you the patches.
> Awesome. In that case lets see what happens if in config/tools/rtems-kernel-4.10.2.cfg oyu change:
> to:
> Chris
