No RTEMS 4.11 in RSB?
Needell, Jerry Jerry.Needell at unh.edu
Sun May 15 00:49:56 UTC 2016
Chris,
I am thoroughly confused with regards to 4.11, but all I want to be able to do is follow the directions on the wiki.
I was trying to demonstrate to someone how to use the RSB to build 4.9 to support maintenance of a project as well as follow the guidance on the wiki to build 4.11. Neither works at present.
My immediate need of being able to build a working 4.9 toolset is satisfied so I am happy to wait for things to settle. I guess I missed something in the evolution form 4.10 to 4.12.
Thanks,
Jerry
> On May 14, 2016, at 5:26 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 13/05/2016 9:55 PM, Needell, Jerry wrote:
>> Chris,
>> That was all it took:
>> 4.10   and 4.9 build fine as long as 2 changes are made:
>> 1)
>> As Jan suggested:
>> delete the line
>> %include rtems-version.bset
>> from rtems/config/rtems-base.bset
> I am not sure this is a good idea. Once we branch 4.9 and 4.10 the base version can be changed and this file works.
>> 2)
>> as you suggested:
>> In config/tools/rtems-kernel-4.10.2.cfg oyu change:
>> %define rtems_kernel_version     4.10.2
>> to:
>> %define rsb_version 4.10.2
>> Note, the hash rtems_kernel_version also needs to change to rsb_version.
> Yes this was needed.
>> I made the same charge for 4.9 but I did not test it without the change - may not have mattered.
>> Note: for 4.9 it is also necessary to install texinfo-4.13 as described in the wiki.
>> But - change #1  now causes 4.12 to fail since items-version is not defined.
>> I’m trying to find a way to keep them all happy!
>> What  is the status of returning 4.11 to the RSB bsets list?
> There is no plan to merge 4.11 back in and there are plans to remove 4.9 and 4.10 and to place them on their own branches just like 4.11. As you can see the ability to support all releases at the same time is complicated. Once 4.9 and 4.10 are split all that needs to change is 4.12 to 4.9 and 4.10 and things should work. Further to this all features in the one version can be confusing to users.
> I need to tag and branch 4.9 and 4.10 and then make a tarball and add it to the FTP server.
> Chris
