LEON3 (GR712RC) Building RTEMS for SMP
Leonard Bise
leonard.bise at syderal.ch
Thu May 26 11:29:22 UTC 2016
So we managed to compile RTEMS but now if we try to build a simple test
application, sparc-rtems4.12-gcc can't find system headers (bsp.h etc...)
However, when comparing to rtems4.10 we have already installed and working,
we find the file in the same directory :
/opt/rtems-4.12/src/rtems-4.12/c/src/lib/libbsp/sparc/leon3/include
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/include
The rtems 4.10 we use is the one built by Gaisler so maybe we are missing
something?
After this I tried executing the hello.exe that is built in the
testsuites/samples folder and it executed just fine on the GR712RC board,
so I guess the toolset is correct.
However if I try to manually build the init.c file I get a missing header
error.
/opt/rtems-4.12/bin/sparc-rtems4.12-gcc init.c -o out
init.c:14:24: fatal error: rtems/test.h: No such file or directory
#include <rtems/test.h>
compilation terminated.
I don't understand why gcc can't find those system header files?
Is our install botched or are we missing something?
*Léonard Bise*
Software Design Engineer
Direct Line +41 (0)32 338 9902
*SYDERAL SA*
Neuenburgstrasse 7
CH-3238 Gals (Switzerland)
Desk Line +41 (0)32 338 9800
Web Site http://www.syderal.ch
2016-05-26 9:53 GMT+02:00 Chris Johns <chrisj at rtems.org>:
> On 26/05/2016 17:41, Leonard Bise wrote:
>> Thanks a lot Chris, the problem is fixed.
> Excellent.
> I'd like to ask also, would it be possible to have a quick status of the
>> current state of the SMP functionality for GR712 in RTEMS?
>> Is it mostly working, or still under active development?
> I am not sure about the specific state of the hardware you are talking
> about and I am sure Sebastian will chime in when he is able.
> SMP should be working on SPARC architectures. Sebastian is working to
> remove the giant lock and to improve the performance. As a result there is
> a great of activity. The end result of his work will be awesome.
> Added to this I am working on improving the user experience with libbsd
> and making a start at documenting something, the getting started guide is
> first. This is resulting in some changes like the one that broke your build.
> Thanks a lot for your help anyway.
> Pleasure.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20160526/1f1037f8/attachment.html>
