Question about rtems compilation
Thu May 26 15:29:56 UTC 2016
The configure script arguments control a few enable/disable of large
features, which may help reduce code size. However, I think what you
really want to understand is how to control the resources allocated by
RTEMS. For that, you should see
https://docs.rtems.org/doc-current/share/rtems/html/c_user/Configuring-a-System.html#Configuring-a-System
and look at some of the testsuites programs for how they work.
Gedare
On Thu, May 26, 2016 at 10:03 AM, Matias Camelli <mcamelli at gmail.com> wrote:
>> Hello guys!!!!
>> First of all, sorry for my english, is very poor, but i'll try to write
>> clear.
>> I need to compile rtems with de minimum requirements i need for my
>> project. For that, i need to cut part of code, but i don't know how to do
>> that. I try to compile rtems with configure script, invoking --disable-<>
>> flags, but i think that this is a wrong way.
>> Any ideas about this?
>> Thanks in advance
>> Matias Camelli
>> (0054) (294) 15-4410740
> users mailing list
> users at rtems.org
