No RTEMS 4.11 in RSB?
Needell, Jerry Jerry.Needell at unh.edu
Tue May 10 14:59:34 UTC 2016
Jan - thanks - that fix allows me to build the 4.10 toolset OK but now if crashes when building the items kernel - I’ll look for similar issues there - progress …
Jerry
On May 10, 2016, at 10:30 AM, Jan Sommer <soja-lists at aries.uberspace.de<mailto:soja-lists at aries.uberspace.de>> wrote:
Am 2016-05-10 15:59, schrieb Gerald Needell:
additionally, if I try to build the 4.10 bset it fails to build binutils
and it there appears to be some misconfiguration with the 4.12
toolset ...
Any suggestions?
There seems to be some problems with the versioning. You can try to comment/delete the line
%include rtems-version.bset
from rtems/config/rtems-base.bset
It looks like it overwrites the global rtems-version variable with 4.12 even if it was set to 4.10 previously.
Cheers,
  Jan
Thanks
Jerry
[rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder
--log=l-sparc-4.10.txt --prefix=$HOME/sandbox/development/rtems/4.10
4.10/rtems-sparc
RTEMS Source Builder - Set Builder, 4.12 (8bcc58b249fb)
Build Set: 4.10/rtems-sparc
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
Creating source directory: sources
download:
https://urldefense.proofpoint.com/v2/url?u=http-3A__downloads.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=tJcqQjQm5LGoqmLHoTXvBre5tRt1F4rSzkiWUsuAg3g&e= -> sources/expat-2.1.0.tar.gz
redirect:
https://urldefense.proofpoint.com/v2/url?u=http-3A__liquidtelecom.dl.sourceforge.net_project_expat_expat_2.1.0_expat-2D2.1.0.tar.gz&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=QOqlnYqJeW1jnG8KkqwpVm-mdJuM3DzHuRGe9kVp2Qk&e= downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
building: expat-2.1.0-x86_64-linux-gnu-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-binutils-2.20.1-1.cfg
package: sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1
download: https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.gnu.org_gnu_binutils_binutils-2D2.20.1.tar.bz2&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=viGpJ6834sjYum0y35mRwTSPkhi3UXpbPInEiZLbhlM&e=  ->
sources/binutils-2.20.1.tar.bz2
downloading: sources/binutils-2.20.1.tar.bz2 - 16.8MB of 16.8MB (100%)
Creating source directory: patches
download:
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=OGE4uI9NT55EyRCXcoxNwBQOVz7ucQAdroTKAzYStDk&e= -> patches/binutils-2.20.1-rtems4.10-20100826.diff
download:
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= error: HTTP Error 404: Not found
error: downloading
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Dtools_plain_tools_4.12_binutils_binutils-2D2.20.1-2Drtems4.10-2D20100826.diff-3A&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=8ioQ3NC2On-rxsGcRZKFRdv1hql_2-g7KAIiAx7s12I&e= all paths have failed, giving up
Build FAILED
 See error report:
rsb-report-sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1.txt
error: downloading
Build Set: Time 0:00:12.468130
Build FAILED
On Tue, 2016-05-10 at 13:39 +0000, Gerald Needell wrote:
When I check for the available bsets I don't see any 4.11 bset.
Where did it go?
Thanks
Jerry
[rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder --list-bsets
Examining: config
Examining: ../source-builder/config
Examining: ../bare/config
   4.10/rtems-all.bset
   4.10/rtems-arm.bset
   4.10/rtems-autotools.bset
   4.10/rtems-avr.bset
   4.10/rtems-bfin.bset
   4.10/rtems-h8300.bset
   4.10/rtems-i386.bset
   4.10/rtems-lm32.bset
   4.10/rtems-m32c.bset
   4.10/rtems-m32r.bset
   4.10/rtems-m68k.bset
   4.10/rtems-mips.bset
   4.10/rtems-nios2.bset
   4.10/rtems-powerpc.bset
   4.10/rtems-sh.bset
   4.10/rtems-sparc.bset
   4.12/rtems-aarch64.bset
   4.12/rtems-all.bset
   4.12/rtems-arm.bset
   4.12/rtems-autotools-base.bset
   4.12/rtems-autotools-internal.bset
   4.12/rtems-autotools.bset
   4.12/rtems-bfin.bset
   4.12/rtems-default.bset
   4.12/rtems-epiphany.bset
   4.12/rtems-i386.bset
   4.12/rtems-lm32.bset
   4.12/rtems-m32c.bset
   4.12/rtems-m68k.bset
   4.12/rtems-microblaze.bset
   4.12/rtems-mips.bset
   4.12/rtems-moxie.bset
   4.12/rtems-nios2.bset
   4.12/rtems-or1k.bset
   4.12/rtems-powerpc.bset
   4.12/rtems-sh.bset
   4.12/rtems-sparc.bset
   4.12/rtems-sparc64.bset
   4.12/rtems-tools.bset
   4.12/rtems-v850.bset
   4.12/rtems-x86_64.bset
   4.9/rtems-all.bset
   4.9/rtems-arm.bset
   4.9/rtems-autotools.bset
   4.9/rtems-i386.bset
   4.9/rtems-m68k.bset
   4.9/rtems-mips.bset
   4.9/rtems-powerpc.bset
   4.9/rtems-sparc.bset
   databases/sqlite.bset
   devel/autotools-base.bset
   devel/autotools-internal.bset
   devel/autotools.bset
   devel/dtc.bset
   devel/libtool.bset
   devel/libusb.bset
   devel/or1ksim.bset
   devel/qemu.bset
   gnu-tools-4.6.bset
   gnu-tools-4.8.2.bset
   graphics/freetype2.bset
   graphics/graphics-all.bset
   graphics/libjpeg.bset
   graphics/libpng.bset
   graphics/libtiff.bset
   graphics/microwindows.bset
   graphics/nxlib.bset
   graphics/t1lib.bset
   lang/gcc491.bset
   net-mgmt/net-snmp.bset
   net/lwip.bset
   net/ntp.bset
   net/protobuf.bset
   rtems-4.10-base.bset
   rtems-4.9-base.bset
   rtems-base.bset
   rtems-package.bset
   rtems-urls.bset
   rtems-version.bset
users mailing list
users at rtems.org<mailto:users at rtems.org>
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=CwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=BDa1FM0KwES5hNvW-2D_tJ2ls6eQZJGqg3UVRVSJlp0&m=g69bRdscm52Qc-TtdiF0a4hARERadpfzSTPAqQAJMjQ&s=pEEEjIK6rr5PNYSUPKmMmB57RLit3ky08iFXiBMVTyU&e=
URL: <http://lists.rtems.org/pipermail/users/attachments/20160510/6c07f560/attachment-0002.html>
