RTEMS 4.11.0 RC4 Available
Needell, Jerry Jerry.Needell at unh.edu
Tue Nov 1 23:16:30 UTC 2016
Hello Amalaye,
On a CENTOS 7 system,  I followed the instructions posted by Chris:
https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc4/
I wanted to test the instructions as well as the source-builder ;-)
After downloading rtems-source-builder-4.11.0-rc4.tar.xz
I did as instructed:
The following builds RTEMS for the SPARC architecture:
 $ cd
 $ mkdir development/rtems
 $ cd development/rtems
 $ tar Jxf rtems-source-builder-4.11.0-rc4.tar.xz
    note - make sure this command points to wherever you downloaded rtems-source-builder-4.11.0-rc4.tar.xz
    or copy it to development/rtems before starting.
 $ cd rtems-source-builder-4.11.0-rc4/rtems
 $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/4.11.0-rc4 4.11/rtems-sparc
No errors were reported.
As to the Virtual Box issue, I had updated my Virtual box just before trying to run the exact same sequence and found that it failed to download the sources with
Error 104 - Connection reset by Peer errors during the ftp transfers.
Here is a link to what I think is the relevant discussion.
https://www.virtualbox.org/ticket/16084
I simply downloaded the Virtual Box package for 5.026 and reinstalled it on my system (Mac mini - MacOs Sierra) and was able to execute the same sequence as above.
Good luck!
Jerry
On Nov 1, 2016, at 6:34 PM, Oyake, Amalaye (398F) <amalaye.oyake at jpl.nasa.gov<mailto:amalaye.oyake at jpl.nasa.gov>> wrote:
Hello Jerry,
Can you please send us the commands you used to run RSB, for those of us who are playing around with various RSB configuration options? This will be helpful to me (and other users) becoming more familiar with the RSB tool.
Also if there is an open issue with VirtualBox 5.0.28, can you also share what the issue is and also provide any weblinks to it. This could also be helpful as well.
Regards,
* Amalaye Oyake                                       *
* Instrument Product Software Development Group  */\  *
* Jet Propulsion Laboratory, Pasadena            *||  *
* CA 91109                                       /||\ *
On 11/1/16, 2:33 PM, "users on behalf of Needell, Jerry" <users-bounces at rtems.org<mailto:users-bounces at rtems.org> on behalf of Jerry.Needell at unh.edu<mailto:Jerry.Needell at unh.edu>> wrote:
   Hi Chris,
   Just wanted to let you know that I was able to build  rtems-sparc via the RSB “out of the box” on my CENTOS 7 system. No problems.
Just a heads up that I first tried building on a newly updated VirtualBox (Virtual Box 5.0.28) and  the ftp downloads failed!
Turns out, there is an “issue” with VirtualBox 5.0.28. reverting to 5.0.26 and it worked fine (actually still building, but no ftp issues!)
Nothing is ever easy!
Thanks for the RSB and for the support,
Jerry
On Oct 31, 2016, at 5:27 PM, Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
RTEMS 4.11.0 RC4
Release: 4.11.0-rc4
Date   : 31 October 2016
URL    : https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.0-2Drc4_&d=DQICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=c0pGS9t_5ksY2r1MTw8ty52uAi4R_YgZGTWtyifm7-s&s=kxI_vZorpl01KQvY0du2adR4paafsyQhiRS5-TgjelM&e=
This is a release candidate for RTEMS 4.11.0.
The release now contains the documentation. The ReST documentation
source is provided along with HTML and PDF archives of each manual for
easy download.
One more release candidate is expected within the next week with the
remaining documentation updates being worked on after which the
documentation repo will be branched. There is also some minor packaging
corrections.
Please download, review, check, build and test sending any issues to the
mailing lists.
To build click on the link and follow the releases README.txt's "Quick
Guide to Building" section.
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DQICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=c0pGS9t_5ksY2r1MTw8ty52uAi4R_YgZGTWtyifm7-s&s=EMzqYl2Qyxb0hhlQXQe9npruwRwla0BIkplpnNhEG2c&e=
users mailing list
users at rtems.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DQICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=c0pGS9t_5ksY2r1MTw8ty52uAi4R_YgZGTWtyifm7-s&s=OmQw0r3Gp9RdLR98Dj-0XeDwEnIMhnBOs_eVUmW1fHI&e=
   users mailing list
   users at rtems.org<mailto:users at rtems.org>
   https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DQIGaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=sZ3Nux3ZW2jONGgU5pLYXiXfC7g8IoKnITO5glhwZRg&s=dR-msWhQ0N6Uy7TuUlEOEvrZUih3Dzu1jUabNHOhj24&e=
URL: <http://lists.rtems.org/pipermail/users/attachments/20161101/185d56b0/attachment-0001.html>
