Reducing the size of an RTEMS application
Wed Nov 2 06:09:37 UTC 2016
On 01/11/16 19:01, Oyake, Amalaye (398F) wrote:
> Thank you for the replies Chris, Joel and Gedare:
> I read the following: https://docs.rtems.org/releases/rtemsdocs-4.6.2/share/rtems/html/FAQ/FAQ00069.html
> And using sparc-rtems4.12-strip (I am using RTEMS ‘4.12’ pulled from git), I got a reduction from 7.3M to 754K, which is more in line with what I expected. However, I am interested in reducing things more.
The strip command is useless to reduce the size on the target. I just
removes meta-data like debug and symbol information.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
