RTEMS 4.11.0 RC4 Available
Needell, Jerry
Jerry.Needell at unh.edu
Thu Nov 3 12:02:51 UTC 2016
Jerry Needell -- jerry.needell at unh.edu<mailto:jerry.needell at unh.edu>
University of New Hampshire
Space Science Center
office phone +1 603 862 2732
cell phone +1 603 969 6723
On Nov 2, 2016, at 6:38 PM, Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
On 02/11/2016 10:16, Needell, Jerry wrote:
Hello Amalaye,
On a CENTOS 7 system, I followed the instructions posted by Chris:
https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.0-2Drc4_&d=DQICaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=Cwj-IQAPGo2SOtRDQ9O29HRm45rlts0Z-C0hYjYK-ck&s=gCiX9xD8kZAHCx_tANz6Qcqq3si6r2abR4yY6dYuzXY&e=
I wanted to test the instructions as well as the source-builder ;-)
Thank you. I cannot express how valuable this feedback is.
You are very welcome!
After downloading rtems-source-builder-4.11.0-rc4.tar.xz
I did as instructed:
The following builds RTEMS for the SPARC architecture:
$ cd
$ mkdir development/rtems
$ cd development/rtems
$ tar Jxf rtems-source-builder-4.11.0-rc4.tar.xz
note - make sure this command points to wherever you downloaded rtems-source-builder-4.11.0-rc4.tar.xz
The source for this file is here ...
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Drelease_tree_README-2Ddoc.txt.in&d=DQICaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=Cwj-IQAPGo2SOtRDQ9O29HRm45rlts0Z-C0hYjYK-ck&s=2jpiDWgUVqiragtjoFAeEN9esYAmZtUfRcDbNM7zCi0&e=
If you would like to add a note to this file and send a patch to devel list that would be awesome. I am close to cutting a final RC for 4.11.0.
My reason of rate comment was that this was the one line that could not just be cut/pasted and required a moment of thought by the user. Perhaps that is not a bad thing!
I suppose you could change
to read
$ tar Jxf /path/to/rtems-source-builder-4.11.0-rc4.tar.xz
Would that be acceptable and helpful or should it just be left as it is?
It becomes obvious very quickly if the tar command does not find the source file ;-)
I’ll make this change and submit the patch - you are welcome to use it or not as you see fit.
URL: <http://lists.rtems.org/pipermail/users/attachments/20161103/c15f9fed/attachment.html>
