How to create a bridge on libbsd?
Thu Nov 10 07:33:51 UTC 2016
Hello Yu Lei,
I suggest to first update to the RTEMS and libbsd Git master and then
try if it already works.
On 10/11/16 06:57, yu lei wrote:
> Dear all,
> I have a board with two network interfaces, and now I can configure
> them up successfully. My rtems version is the master version in May, 2016.
> However, I failed to create a bridge and set interfaces as its
> members. Referring to tutorial[1] from freebsd about bridge, I try to
> use "ifconfig bridge create", "ifconfig bridge0 addm iface0 addm
> iface1up" to create it using rtems_bsd_command_ifconfig().
> What I got from terminal is "ifconfig SIOCIFCREATE2: Invalid argument"
> and an command execution failure.
> I also notice that libbsd support rc.conf in June but I havn't tried
> it. Will it be helpful to setup a bridge and does ifconfig support
> bridge operation?
> Best regards,
> Yu Lei
> [1] https://www.freebsd.org/doc/handbook/network-bridging.html
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
