Problems building raspberry bsp
Markus totersuizit at yahoo.de
Thu Nov 10 12:44:38 UTC 2016
No, I don't use the master branch as described. I use the 4.11 branch.
Would it be better to base on masters branch when developing a new bsp?
Am 10.11.2016 um 11:55 schrieb Sebastian Huber:
> Are you sure you use the latest RTEMS master? Looks like you use an
> old select.h with a new tool chain. Try to remove the build directory
> and start from scratch.
