Crash in RTEMS when doing TCP communication.
Fri Nov 11 07:55:26 UTC 2016
An off hand guess is that you use an already closed file descriptor and thus access freed memory and destroyed data structures.
----- Ben Dart <Ben.Dart at adept.com> schrieb:
> I have a program for RTEMS 4.9.2. This works for most applications but we are having some issues right now. We are sending TCP packets to the system running RTEMS, if the tcp port is open and receiving and we are replying etc, everything works fine. But if we stop the tcp receiver, eventually we get a crash in RTEMS. We have had the following few stack dumps:
> CRASH 1
> 0x3A010000 : bsp_ram_size
> 0x0032DED4 : soisconnected
> 0x0035D0F0 : tcp_input
> 0x0031914C : ip_input
> 0x00319C80 : ipintr
> 0x00323124 : rtems_bsdnet_event_receive
> 0x00323298 : soconnsleep
> 0x0036E980 : _Thread_Handler
> 0x0036E904 : _Objects_API_maximum_class
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
