ERROR : git command failed (/usr/bin/git): 128
Sagar Gupta
sagarguptamonu1996 at gmail.com
Fri Nov 11 17:11:28 UTC 2016
I was trying to run the hello world program while building rsb the
following error occurred ,please help with the following error
,attached the error report
>git: fetch: git://git.rtems.org/rtems-tools.git ->
sources/git/rtems-tools.git
>error: git command failed (/usr/bin/git): 128
>Build FAILED
> See error report: rsb-report-rtems-tools-HEAD-1.txt
>Build Set: Time 0:52:13.515762
>Build FAILED
thanking you
Sagar Gupta
URL: <http://lists.rtems.org/pipermail/users/attachments/20161111/7050b64e/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: git command failed (/usr/bin/git): 128
Command Line: ../source-builder/sb-set-builder --prefix=/home/stark/development/rtems/4.12 4.12/rtems-sparc
Python: 2.7.6 (default, Jun 22 2015, 17:58:13) [GCC 4.8.2]
git://git.rtems.org/rtems-source-builder.git/origin/534332f22a66f16b4022e87ae50c11ff20c98dcb-modified
Linux stark-Inspiron-3542 4.4.0-38-generic #57~14.04.1-Ubuntu SMP Tue Sep 6 17:20:43 UTC 2016 x86_64
Tail of the build log:
make[5]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/testsuite'
make[5]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/data-directory'
make[6]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/data-directory'
/bin/bash ../../../gdb-7.11/gdb/data-directory/../../mkinstalldirs /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/syscalls
mkdir -p -- /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/syscalls
files='gdb-syscalls.dtd arm-linux.xml aarch64-linux.xml ppc-linux.xml ppc64-linux.xml i386-linux.xml amd64-linux.xml sparc-linux.xml sparc64-linux.xml mips-o32-linux.xml mips-n32-linux.xml mips-n64-linux.xml s390-linux.xml s390x-linux.xml' ; \
for file in $files; do \
f=../../../gdb-7.11/gdb/data-directory/../syscalls/$file ; \
if test -f $f ; then \
/usr/bin/install -c -m 644 $f /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/syscalls ; \
fi ; \
done
files='gdb/__init__.py gdb/frames.py gdb/FrameIterator.py gdb/FrameDecorator.py gdb/types.py gdb/printing.py gdb/unwinder.py gdb/prompt.py gdb/xmethod.py gdb/command/__init__.py gdb/command/xmethods.py gdb/command/frame_filters.py gdb/command/unwinders.py gdb/command/type_printers.py gdb/command/pretty_printers.py gdb/command/prompt.py gdb/command/explore.py gdb/function/__init__.py gdb/function/caller_is.py gdb/function/strfns.py gdb/printer/__init__.py gdb/printer/bound_registers.py' ; \
if test "x$files" != x ; then \
for file in $files ; do \
dir=`echo "$file" | sed 's,/[^/]*$,,'` ; \
/bin/bash ../../../gdb-7.11/gdb/data-directory/../../mkinstalldirs /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/python/$dir ; \
/usr/bin/install -c -m 644 ./python/$file /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/python/$dir ; \
done ; \
fi
mkdir -p -- /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/python/gdb/command
mkdir -p -- /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/python/gdb/function
mkdir -p -- /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/python/gdb/printer
files='' ; \
/bin/bash ../../../gdb-7.11/gdb/data-directory/../../mkinstalldirs /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/guile/$dir ; \
/usr/bin/install -c -m 644 ./guile/$file /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/guile/$dir ; \
done ; \
fi
/bin/bash ../../../gdb-7.11/gdb/data-directory/../../mkinstalldirs /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/system-gdbinit
mkdir -p -- /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/system-gdbinit
files='elinos.py wrs-linux.py' ; \
f=../../../gdb-7.11/gdb/data-directory/../system-gdbinit/$file ; \
/usr/bin/install -c -m 644 $f /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/gdb/system-gdbinit ; \
fi ; \
done
make[6]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/data-directory'
make[5]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/data-directory'
make[5]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[6]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[7]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make all-recursive
make[8]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[9]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[9]: Nothing to be done for `all-am'.
make[9]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[8]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[7]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[6]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[7]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make install-recursive
make[10]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[11]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
if test yes = no; then \
case 'linux-gnu' in \
darwin[56]*) \
need_charset_alias=true ;; \
darwin* | cygwin* | mingw* | pw32* | cegcc*) \
need_charset_alias=false ;; \
esac ; \
else \
need_charset_alias=false ; \
fi ; \
if $need_charset_alias; then \
/bin/bash ../../../../gdb-7.11/gdb/gnulib/../../mkinstalldirs /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib ; \
fi ; \
if test -f /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.alias; then \
sed -f ref-add.sed /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.alias > /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.tmp ; \
/usr/bin/install -c -m 644 /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.tmp /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.alias ; \
rm -f /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.tmp ; \
else \
sed -f ref-add.sed charset.alias > /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/lib/charset.tmp ; \
fi ; \
fi
make[11]: Nothing to be done for `install-data-am'.
make[11]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[10]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[7]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[5]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[4]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb'
make[3]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb'
make[2]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb'
make[1]: Nothing to be done for `install-target'.
make[1]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build'
+ /bin/rm -rf /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/info/configure.info*
+ /bin/rm -f /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/info/dir
+ touch /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/info/dir
==> %clean:
+ cd /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
+ echo ==> %clean:
copy: /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root => /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc
reporting: tools/rtems-gdb-7.11-1.cfg -> sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1.txt
making dir: /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1-root-root/home/stark/development/rtems/4.12/share/rtems/rsb
reporting: tools/rtems-gdb-7.11-1.cfg -> sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1.xml
config: tools/rtems-tools-4.12-1.cfg
package: rtems-tools-HEAD-1
script: 1: #!/bin/sh
script: 2: # ___build_pre in as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/stark/development/rtems/4.12"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/stark/development/rtems/4.12" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/sources"
script: 9: SB_BUILD_DIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/rtems-tools-HEAD-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: SB_HOST_CFLAGS="-O2 -pipe "
script: 13: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 14: SB_HOST_LDFLAGS=" -L/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 15: SB_BUILD_CFLAGS="-O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 17: SB_BUILD_LDFLAGS=" -L/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 18: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 19: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 20: SB_ARCH="x86_64"
script: 21: SB_OS="linux"
script: 22: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 23: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 24: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 25: export SB_CFLAGS SB_CXXFLAGS
script: 26: # Documentation
script: 27: SB_DOC_DIR="/home/stark/development/rtems/4.12/share/doc"
script: 28: export SB_DOC_DIR
script: 29: # Packages
script: 30: SB_PACKAGE_NAME="rtems-tools-HEAD-1"
script: 31: SB_PACKAGE_BUILDNAME="rtems-tools-HEAD-1"
script: 32: SB_PACKAGE_VERSION="HEAD"
script: 33: SB_PACKAGE_RELEASE="1"
script: 34: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 35: # Build directories
script: 36: export SB_PREFIX
script: 37: SB_BUILD_DIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/rtems-tools-HEAD-1"
script: 38: SB_BUILD_ROOT="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/rtems-tools-HEAD-1-root-root"
script: 39: SB_BUILD_ROOT_BINDIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/rtems-tools-HEAD-1-root-root/${SB_PREFIX_CLEAN}/bin"
script: 40: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 41: SB_BUILD_CXC_DIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/rtems-tools-HEAD-1-cxc"
script: 42: SB_BUILD_CXC_ROOT="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/rtems-tools-HEAD-1-root-cxc"
script: 43: SB_BUILD_CXC_ROOT_BINDIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/rtems-tools-HEAD-1-root-cxc/${SB_PREFIX_CLEAN}/bin"
script: 44: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 45: SB_TMPROOT="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc"
script: 46: SB_TMPPREFIX="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 47: SB_TMPBINDIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 48: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 49: SB_TMPCXCROOT="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root/4.12/rtems-sparc"
script: 50: SB_TMPCXCPREFIX="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root-cxc/4.12/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 51: SB_TMPCXCBINDIR="/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-root-cxc/4.12/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 52: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 53: # Extra path support
script: 54: SB_EXTRAPATH="/home/stark/development/rtems/rsb/rtems-source-builder/source-builder"
script: 55: # The compiler flags
script: 56:
script: 57:
script: 58: export CFLAGS_FOR_TARGET
script: 59: export CXXFLAGS_FOR_TARGET
script: 60: # Set up the path. Put the CXC path first.
script: 61: if test -n "${SB_TMPBINDIR}" ; then
script: 62: PATH="${SB_TMPBINDIR}:$PATH"
script: 63: fi
script: 64: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 65: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_EXTRAPATH}" ; then
script: 68: PATH="${SB_EXTRAPATH}:$PATH"
script: 69: fi
script: 70:
script: 71:
script: 72: export PATH
script: 73: # Default environment set up.
script: 74: LANG=C
script: 75: export LANG
script: 76: unset DISPLAY || :
script: 77: umask 022
script: 78: cd "/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/rtems-tools-HEAD-1"
script: 79: echo "=> rtems-tools-HEAD-1:"
script: 80: echo "==> %prep:"
script: 81: build_top=$(pwd)
script: 82: rtems_tools_source="rtems-tools.git"
script: 83: source_dir_rtems_tools=${rtems_tools_source}
source setup: rtems-tools-HEAD-1: source rtems-tools -q -n ${rtems_tools_source}
making dir: /home/stark/development/rtems/rsb/rtems-source-builder/rtems/sources/git
git: reset: git://git.rtems.org/rtems-tools.git
git: fetch: git://git.rtems.org/rtems-tools.git -> sources/git/rtems-tools.git
