Help with GDB on Powerpc Targets
Matt Rippa
mrippa at gemini.edu
Fri Nov 18 17:15:11 UTC 2016
Looking for guidance running gdb on ppc targets. Remote debugging would be
ideal, but any method of setting a break point or seeing a stack trace
would help.
Is there a resource I can start reading to set this up? My three bsp's are
below.
Thank you,
-Matt
../rtems-4.10.2/configure --target=powerpc-rtems4.10
--prefix=/gem_sw/targetOS/RTEMS/rtems-4.10 --enable-cxx --enable-rdbg
--disable-tests --enable-networking --enable-posix --enable-readline
--enable-rtemsbsp="beatnik mvme2307 mvme3100"
URL: <http://lists.rtems.org/pipermail/users/attachments/20161118/1f9eea96/attachment.html>
