Help with GDB on Powerpc Targets
Matt Rippa
mrippa at gemini.edu
Sun Nov 20 03:19:52 UTC 2016
I found this on Till's page.
http://www.slac.stanford.edu/~strauman/rtems/gdb/index.html
Looks like all my bsp's are mentioned.
-Matt
On Fri, Nov 18, 2016 at 7:15 AM, Matt Rippa <mrippa at gemini.edu> wrote:
> Looking for guidance running gdb on ppc targets. Remote debugging would be
> ideal, but any method of setting a break point or seeing a stack trace
> would help.
> Is there a resource I can start reading to set this up? My three bsp's are
> below.
> Thank you,
> -Matt
> ../rtems-4.10.2/configure --target=powerpc-rtems4.10
> --prefix=/gem_sw/targetOS/RTEMS/rtems-4.10 --enable-cxx --enable-rdbg
> --disable-tests --enable-networking --enable-posix --enable-readline
> --enable-rtemsbsp="beatnik mvme2307 mvme3100"
URL: <http://lists.rtems.org/pipermail/users/attachments/20161119/de34f250/attachment.html>
