AW: How to get CPU usage report in binary form to a user-variable ?
Wed Nov 23 11:41:02 UTC 2016
Hello Rolf,
On 23/11/16 11:26, Rolf.Schroedter at dlr.de wrote:
> Hello Sebastian,
> thank you for your quick reply.
> I am thinking about to write such a little function based on the rtems_cpu_usage_report() source
> at application level.
> (We do not want to recompile the complete RTEMS).
from an RTEMS project point of view it would be better to fix this issue
in the master branch, since your use case seems to be quite reasonable.
> Do you think this will be possible ?
> Will I have access to all information , or is it hidden ?
Just copy and paste and modify the rtems_cpu_usage_report()
implementation. This will work for the moment, however, it will probably
not work with the next RTEMS version you use and nobody else can benefit
from it.
> Best regards,
> Rolf
>> -----Ursprüngliche Nachricht-----
>> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Gesendet: Mittwoch, 23. November 2016 11:10
>> An: Schrödter, Rolf; users at rtems.org
>> Betreff: Re: How to get CPU usage report in binary form to a user-variable ?
>> Hello,
>> this is currently not covered by the user API. We would have to change
>> the CPU usage report to provide binary data and then add a consumer
>> which prints the information as a specialization. Something like
>> rtems_profiling_iterate() and rtems_profiling_report_xml().
>> On 23/11/16 10:58, Rolf.Schroedter at dlr.de wrote:
>>> Hello,
>>> I am aware of the function
>>> printing the CPU usage to console.
>>> However is it possible to get the same information into a
>>> user-variable (e.g. a structure/array) ?
>>> We would like to have this information in a binary form for further
>>> processing and/or sending this data to telemetry.
>>> Thanks and regards,
>>> Rolf.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
