Overrun Handling for Mixed-Criticality Support in RTEMS
Kuan Hsun Chen
kuan-hsun.chen at tu-dortmund.de
Wed Nov 30 20:44:52 UTC 2016
Hi,
Here is the version of the document I refine for RMS.
Best,
Kuan-Hsun
2016-11-30 14:56 GMT+00:00 Kuan Hsun Chen <kuan-hsun.chen at tu-dortmund.de>:
> Hello,
> Please find my patch in the attachment. (It is a ticket with #2795)
> In the patch, some variables are added and the control flows of the
> periodicity routine and the watchdog routine are refined.
> The patch includes two executable examples (I test on Qemu with a
> uniprocessor), one for fixed-priority scheduling called sprmsched01 and
> another one for EDF called spedfsched04.
> I will update the user manual later on.
> Best,
> Kuan-Hsun
> 2016-11-04 13:34 GMT+00:00 Sebastian Huber <sebastian.huber at embedded-brai
> ns.de>:
>> Hello,
>> I would like to get a bit more attention for this RTEMS flaw:
>> https://devel.rtems.org/ticket/2795
>> The problem is nicely described here:
>> http://ls12-www.cs.tu-dortmund.de/daes/media/documents/publi
>> cations/downloads/2016-wmc.pdf
>> I would like to fix this without adding new options to the Classic API,
>> so just change the behaviour as described in the paper in case a period
>> miss occurs. Any objects from the RTEMS user point of view?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> M.Sc. Kuan-Hsun Chen
> TU Dortmund
> Department of Computer Science 12
> Design Automation of Embedded Systems
> Otto-Hahn-Strasse 16, Room 102
> 44227 Dortmund
> Germany
> Phone: *+49 231 755 6124 <+49%20231%207556124>*
> Mail: kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
TU Dortmund
44227 Dortmund
Germany
Phone: *+49 231 755 6124*
URL: <http://lists.rtems.org/pipermail/users/attachments/20161130/d1971c7e/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20161130/d1971c7e/attachment-0001.obj>
