AW: AW: How to get CPU usage report in binary form to a user-variable ?
Rolf.Schroedter at dlr.de
Wed Nov 23 12:31:56 UTC 2016
Hello Sebastion,
off course you are right concerning the RTEMS fix.
What would be needed is to define a public structure for CPU usage data
and to split rtems_cpu_usage_report() into two parts: 1. getting data and 2. printing it.
I will make an application-level implementation first and put the RTEMS patch on my TODO list...
(at least for the RTEMS_ENABLE_NANOSECOND_CPU_USAGE_STATISTICS branch)
Thanks & regards,
Rolf
> -----Ursprüngliche Nachricht-----
> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Gesendet: Mittwoch, 23. November 2016 12:41
> An: Schrödter, Rolf; users at rtems.org
> Betreff: Re: AW: How to get CPU usage report in binary form to a user-
> variable ?
> Hello Rolf,
> On 23/11/16 11:26, Rolf.Schroedter at dlr.de wrote:
> > Hello Sebastian,
> > thank you for your quick reply.
> > I am thinking about to write such a little function based on the
> rtems_cpu_usage_report() source
> > at application level.
> > (We do not want to recompile the complete RTEMS).
> from an RTEMS project point of view it would be better to fix this issue
> in the master branch, since your use case seems to be quite reasonable.
> > Do you think this will be possible ?
> > Will I have access to all information , or is it hidden ?
> Just copy and paste and modify the rtems_cpu_usage_report()
> implementation. This will work for the moment, however, it will probably
> not work with the next RTEMS version you use and nobody else can benefit
> from it.
> > Best regards,
> > Rolf
> >> Gesendet: Mittwoch, 23. November 2016 11:10
> >> Betreff: Re: How to get CPU usage report in binary form to a user-variable
> >> Hello,
> >> this is currently not covered by the user API. We would have to change
> >> the CPU usage report to provide binary data and then add a consumer
> >> which prints the information as a specialization. Something like
> >> rtems_profiling_iterate() and rtems_profiling_report_xml().
> >> On 23/11/16 10:58, Rolf.Schroedter at dlr.de wrote:
> >>> Hello,
> >>> I am aware of the function
> >>> printing the CPU usage to console.
> >>> However is it possible to get the same information into a
> >>> user-variable (e.g. a structure/array) ?
> >>> We would like to have this information in a binary form for further
> >>> processing and/or sending this data to telemetry.
> >>> Thanks and regards,
> >>> Rolf.
> >>> _______________________________________________
> >>> users mailing list
> >>> users at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/users
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
