Rate Monotonic Manager
Agostino Mascitti agostino.mascitti at student.univaq.it
Sun Oct 9 15:56:51 UTC 2016
Dear all,
I am trying to understand the Rate Monotonic Manager. I think I am not understanding something.
As you can see in the attached file, I defined
#define CONFIGURE_MICROSECONDS_PER_TICK     1000000 /* Every 1 sec a tick */
and I would like a task to be executed every 4 seconds: rtems_rate_monotonic_period(periodid, 4);
The strange thing is that the task is executed every 2 seconds.
I read the user guide and, as I understand, in the first iteration of the while loop rtems_rate_monotonic_period should not block. In the second iteration, instead, it should block for 4 sec minus the time used to perform the periodic actions. When this time expires, the 4 seconds period should start another time.
Could anybody say to me what I am not understanding well please?
Thank you another time,
Agostino
URL: <http://lists.rtems.org/pipermail/users/attachments/20161009/f5968721/attachment.html>
Desc: Makefile
URL: <http://lists.rtems.org/pipermail/users/attachments/20161009/f5968721/attachment.obj>
Type: text/x-csrc
Desc: test.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20161009/f5968721/attachment.bin>
