rtems_task_wake_after doubles the actual period
xuelin.tian at qkmtech.com xuelin.tian at qkmtech.com
Tue Oct 11 04:35:47 UTC 2016
Dear all,
When I used rtems_task_wake_after function to delay like 10s, (rtems_task_wake_after(1000), the default tick is 10ms), the actual period was incorrect, which doubled the set value. Then I checked the <bspopts.h>, and modified the BSP_ARM_A9MPCORE_PERIPHCLK value without rebuilding RTEMS . But nothing chaned.
So, do I need to modify the corresponding value in <configure.ac>, and rebuild my BSP? Or, is there other way to correct this bug without modifying the value and rebuilding the code?
Best wishes,
Tim Tian
URL: <http://lists.rtems.org/pipermail/users/attachments/20161011/ce719b2f/attachment.html>
